Installing HIDs. Need help with Wires.
kent55
I moved this to the 4th Gen 05-09 Legacy section
installing-hids-need-help-wires
Hi. I'm installing H7 HIDs in my low beams and can't figure out the best way to connect the bulb wire to the ballast. Do I need to drill a hole through the waterproof cover?
Also I was planning to use an upgraded wiring harness that connects to the battery that would require the female end of the headlight plug to be on the outside of the housing. Do I need to splice into the harness before that wire goes through the headlight housing.... Or can I buy the harness adapter and make my own harness with out affecting the original?
Lastly, how do I remove the headlight housings if needed? Does the bumper need to come off?
