Matt166 Posted May 19, 2015 Share Posted May 19, 2015 Wondered if anyone has experience with these? http://www.rallitek.com/springs/6252-rallitek-rear-overload-springs-legacy-2000-2009.html My query is, these are not labelled as sedan or wagon specific, so I assume they are 10% stiffer than the sedan version. Wagon springs are already stiffer than sedan springs, but by how much? Are they already 10% stiffer? I am always carrying a little weight in my wagon, looking for my car to not squat down as much but still keep regular height. Link to comment Share on other sites More sharing options...
derkahn Posted May 29, 2015 Share Posted May 29, 2015 mine just showed up today.. I will let you know how it goes.. btw .. anyone have a diagram for proper assembly/order/torque specs for the bilstein HD kit.. many washers and bits, many options for me to do it wrong.. Link to comment Share on other sites More sharing options...
Matt166 Posted May 30, 2015 Author Share Posted May 30, 2015 Thanks, appreciate it. Im most interested in how much extra stiffness compared to normal wagon springs - im assuming the spring is the same height next when you put it next to your stocker? Link to comment Share on other sites More sharing options...
Cerebral_1 Posted June 14, 2015 Share Posted June 14, 2015 I just bought some Rallitek springs for my OBXT (but raised height instead of standard height) and installed them last week--rears only. If they're the same as the ones you're asking about...I think they're designed to be like 18% stiffer than the wagon springs. So far, they are much stiffer than the prior setup, but not overly stiff. The back end doesn't bounce or sag anymore. In fact, I just drove about 1000 miles on a road trip loaded down, and the handling, etc. did not feel any different than before it was loaded down. The improvement is awesome! As a caveat...it's hard to tell how much of the improvement is from the new struts vs. the new springs. derkahn, I put my springs on KYBs, so I have no info on putting them on Bilsteins. Hopefully someone else can chime in. Link to comment Share on other sites More sharing options...
Cerebral_1 Posted June 14, 2015 Share Posted June 14, 2015 BTW, the Rallitek raised height springs are surprisingly SHORTER than the OEM ones! Link to comment Share on other sites More sharing options...
Matt166 Posted June 17, 2015 Author Share Posted June 17, 2015 These dissapeared from the website so I asked why, got this response - We've currently disabled them for some more research and development. We had a fitment problem with one particular model and it caused us to pull the product to look over the applications. We will be trying very hard these next few days to get it all sorted. Once the product is available, there is a possibility that the link you have/had saved may not direct you to the same product and will require you to lookup the product again. We are sorry for this inconvenience. Check back Friday, we should have it back up by then at the VERY latest! Link to comment Share on other sites More sharing options...
Cerebral_1 Posted June 18, 2015 Share Posted June 18, 2015 Is this the kit you were looking at? http://www.rallitek.com/springs/6512-rallitek-raised-springs-kit-legacy-2004-2009.html Here is the one I ordered for my Outback: http://www.rallitek.com/springs/5634-rallitek-rear-overload-springs-outback-2000-2014.html Apparently, the standard height springs are on backorder right now. Link to comment Share on other sites More sharing options...
Matt166 Posted June 18, 2015 Author Share Posted June 18, 2015 these were the ones I was looking at - standard height on an LGT wagon just a little stiffer: http://www.rallitek.com/springs/6252-rallitek-rear-overload-springs-legacy-2000-2009.html Seems they are still not back up, just the outback, I wonder if someone somewhere had a problem with them. Link to comment Share on other sites More sharing options...
Matt166 Posted August 15, 2015 Author Share Posted August 15, 2015 Update on these, installed them and very happy with the height. Havent had the chance to load her up yet so cant comment on the extra stiffness. Pics to follow in my build thread on the fourth gen section. Link to comment Share on other sites More sharing options...
