Sludgeroo Posted March 11, 2013 Share Posted March 11, 2013 I want to run a vac gauge to see if I have a vac leak at certain points, the plan was to just tap the line with a T fitting and run a hard hose into the cabin. Im moreso doing this as an experiment/real-time check. MAF seems to have vacuum from the inside of the manifold, as no vac lines appear to be routed to it externally. Would it be ok to tap the FPR vac line? Hopefully someone can let me know here soon. Link to comment Share on other sites More sharing options...
snederhiser Posted March 11, 2013 Share Posted March 11, 2013 Hello; Yes you can put a tee fitting on the line to intake manifold. Steven. Link to comment Share on other sites More sharing options...
Sludgeroo Posted March 11, 2013 Author Share Posted March 11, 2013 Appreciate it Steven Link to comment Share on other sites More sharing options...
