Nbalcom Posted June 23, 2012 Share Posted June 23, 2012 I'm going to replace the HG's on my new engine (1995 Legacy EJ22, swapped in place of a Gen 1 EJ25 in '97 GT) as PM and wondering if any significant gains from swapping heads. I have searched for a while this morning for some data on cylinder heads. I've found some good numbers for the SOHC heads but not DOHC. I would love to have a good comparison on chamber CC and flow for stock heads for a '95 EJ22 SOHC vs '97 EJ25 DOHC. Also, I hear (from WIKI, for whatever that's worth) that 97 and later 2.2 pistons have a slightly improved design that benefits HP and MPG about 10%. Would it be worthwhile to swap pistons? I drive about 2,800 miles a month so 10% = $$$$. I currently get just over 25 MPG and expect an improvement with new tires on monday. Or - other thoughts? I'm used to driving about 300 HP domestics and while I enjoy the lightness of the subie, the handling, and the MPG, I would definately enjoy a little more go. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 26, 2012 Share Posted June 26, 2012 300 HP out of a H4 N/A Subaru engine isnt cheap, sustainable, realistic. Forget that idea. Second No gains from swapping heads and they wont fit the EJ25D bottom end. THe benefits you read pertain to Phase 1 vs Phase 2 engines and a inter-pahse revision of the EJ25D. In short stay with either the EJ25D or the EJ22E Link to comment Share on other sites More sharing options...
Nbalcom Posted June 27, 2012 Author Share Posted June 27, 2012 Thanks for the feedback. I was not suggesting to get 300 HP from my Subie, just stating that I'm used to a lot more power and would like to add a little power in a way that would not overly hinder mileage. The EJ25 DOHC heads DO fit on an EJ22 block, just in case anyone wonders. I put that together for my dad's car a couple years ago just because its what was around. It works surprisingly well despite at least a half point drop in compression. I haven't ever driven the car, but from the passenger seat it FEELS torquier than mine. But that could be that his is 5 speed and mines auto. I still would like to see flow numbers for DOHC heads if any one's seen them... Link to comment Share on other sites More sharing options...
