Air Conditioning cutting out
Monkeyshack
Hello,
In my commute to work I noticed the AC cutting out and for a slight second blowing warm air. Anyone else noticing this? We are getting into the 100’s down here and I just want to make sure something is wrong and that this isn’t normal.
Shouldn’t the AC be on a constant flow? Or does it/can it cut out for a slight second (which could be vital to my survival… ha)?
Normal. Do a search and read up on the Climate Control.
Or ... Read the sticky at the top of the forum. All is cleard up there. You could just go to manual mode also instead of Auto.
Yeah it seems like it gets confused with the dual ac, i find that if i keep them both down around 68 it seems to stay cool most of the time except when im on the highway.. Probably my only real gripe with the car. Hopefully they'll figure it out and issue a TSB to fix it
If everything seems under control, you're just not going fast enough. - Mario Andretti
