rallysquirrel Posted July 31, 2006 Share Posted July 31, 2006 Since the stock SpecB tires are 215/45R18 at 24 lbs and 25.7" OD, 17" for winter options would be : 215/50R17.6% smaller or 205/55R17 1% smaller than stock 225/50R17 .9 smaller than stock (IMO 225 is already too wide for snow) Available tires in 215/50R17 Bridgestone Blizzak WS-50 tirerack.com Dunlop Graspic DS-2 Dunlop SP Winter Sport M3 Nokian WR ----------98v rating 21.6lbs OD26.3 -------215/50R17XL are 95V 21.4# OD 25.5 Pirelli Winter 210 Yokohama Ice Guard IG721 205/55R17 ContiWinterContact TS810 S tirerack.com Michelin Pilot Alpin PA2 225/50R17 Bridgestone Blizzak LM-22 Bridgestone Blizzak WS50 Dunlop Graspic DS-2 Dunlop SP Winter Sport M3 Hankook Ice Bear W300 Michelin Pilot Alpin PA2 Nokian Hakka 4 Nokian RSi Nokian WR Pirelli Winter 210 I decided to go with RSi in 205/50R17. While a .4" smaller overall than SpecB, it will get me through the worst of winter. If anyone has any other options let me know, I'll be updating this. Link to comment Share on other sites More sharing options...
tantal Posted August 2, 2006 Share Posted August 2, 2006 I'd recommend the thinnest tire you can stand, the 205/55r17, or the 215/50r17. There's a Nokian dealer around there somewhere - go to the website. In the 205 size, both of those are, afaik, excellent choices - I've run the arctic alpin in the past with good results, the pilot is more performance oriented. The conti is what I am going to use on my car here in MA. The graspic is a fairly low performance tire, under all conditions there are better choices like the blizzak ws-50. the wintersport is a good tire too, more performance oriented. Basically if you are looking for the best snow and ice performance, you'll want the ws-50, the hakka (2 I thought), or the TS810. For a more dry performance oriented tire with a firmer sidewall, I think the best choices are the the pilot, the WR, wintersport M3, or the LM-22, in that order IMO, but I could be wrong. I used to live in Clifton Park, btw. Hi old neighbor! Link to comment Share on other sites More sharing options...
rallysquirrel Posted August 2, 2006 Author Share Posted August 2, 2006 I'm not yet sure which I'm getting. I had Gislaved NordFrost on my WRX, but they're too soft for rallyX. Plus they don't make them in 17". I just wanted let people the people know what kind options there are for specB. Link to comment Share on other sites More sharing options...
ilh Posted August 2, 2006 Share Posted August 2, 2006 You could also drop down to LGT sizes of 205/50R17, 215/45R17, or 225/45R17 and have your speedo recalibrated by the dealer. Let's face it, a SpecB pretty much is an LGT. I suppose spare tire size would be an issue then though. Link to comment Share on other sites More sharing options...
