imfamousG Posted July 20, 2012 Share Posted July 20, 2012 so i have a 98 lgt wagon and was wondering if this would be a direct bolt on to my car? i have red the stickies but i still dont know if this would work or if i need to add some piping to it. so if anyone knows could ya let me know? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 20, 2012 I Donated Share Posted July 20, 2012 not a direct fit -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
imfamousG Posted July 23, 2012 Author Share Posted July 23, 2012 what will i have to do to make it work? Link to comment Share on other sites More sharing options...
WESTcoast Posted July 23, 2012 Share Posted July 23, 2012 The midpipe will need to be extended and then modified as the rs's rear diff sits a bit higher along and ours a bit lower. so the bending of the angled part will be different. If you are not doing this yourself best to let a shop determine what all needs to be done which will be extending the mid pipe and changing some of the hangers around to fit. I have the same exhaust. If you are going to be cutting and rewelding it yourself, when putting it up you will see what all you will need to do. Link to comment Share on other sites More sharing options...
imfamousG Posted July 24, 2012 Author Share Posted July 24, 2012 how does it sound? Link to comment Share on other sites More sharing options...
WESTcoast Posted July 24, 2012 Share Posted July 24, 2012 sounds really good i have ebay ueql headers and it sounds pretty good deep rumble! Right now i have an exhaust leak so i can't take a great sound clip. Link to comment Share on other sites More sharing options...
Stasis Posted July 25, 2012 Share Posted July 25, 2012 Subaru rumble <3 Link to comment Share on other sites More sharing options...
imfamousG Posted July 25, 2012 Author Share Posted July 25, 2012 sounds really good i have ebay ueql headers and it sounds pretty good deep rumble! Right now i have an exhaust leak so i can't take a great sound clip. do you have the downpipe with it? and how did you do it? did you take it to a shop or do it yourself? Link to comment Share on other sites More sharing options...
WESTcoast Posted July 25, 2012 Share Posted July 25, 2012 I have the catback, there is no downpipe as mine was off an 2.5rs. I first test fitted it and saw how short it was then just took it to an exhaust shop and they knew what to do. Link to comment Share on other sites More sharing options...
imfamousG Posted July 26, 2012 Author Share Posted July 26, 2012 i know that the catback wouldnt have a downpie. what i ment was did you get a catless or high flow cat downpipe with the headers and how much did that cost? Link to comment Share on other sites More sharing options...
imfamousG Posted December 10, 2012 Author Share Posted December 10, 2012 how long do you think the extension will need to be? Link to comment Share on other sites More sharing options...
subikid90 Posted December 10, 2012 Share Posted December 10, 2012 Your car does not have a downpipe..... -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted December 10, 2012 Share Posted December 10, 2012 how does it sound? [ame=http://www.youtube.com/watch?v=oMFqfZfdXrU]1998 Subaru Legacy GT Limited w/DOHC EJ22E - YouTube[/ame] I have an exhaust like the one you're describing. This is more or less what to expect from it. Midpipe has to be cut & extended & make SURE you don't use any of that AZ steel. Trust me on that... Link to comment Share on other sites More sharing options...
Grimmrican Posted December 11, 2012 Share Posted December 11, 2012 Your car does not have a downpipe..... If I'm not mistaken it's: headers, cat1 cat2 (bolts up to cat1), resonator, then muffler. So yes no down pipe up pipe if ur turbo. But that's a separate story Link to comment Share on other sites More sharing options...
98legwag Posted December 11, 2012 Share Posted December 11, 2012 My friend just put one on his 99 sedan. He had to extend the mid pipe. He also cut off all the hangers and welded on his own. Link to comment Share on other sites More sharing options...
