Specbobae Posted December 30, 2010 Share Posted December 30, 2010 are there any mating problems with an invidia downpipe and cobb catback? Link to comment Share on other sites More sharing options...
SBT Posted December 30, 2010 Share Posted December 30, 2010 Yes - flat 3" flange on Invidia to a 2.5" donut flange on CB. You'll need an adapter (plus flat and donut gaskets). - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Drift Motion Posted December 30, 2010 Share Posted December 30, 2010 if the size are the same, your good to go if one is 3 inch and other is 2.5, get an adapter, then your good to go Link to comment Share on other sites More sharing options...
Specbobae Posted December 30, 2010 Author Share Posted December 30, 2010 thanks for the feedback, can anybody tell me how much an adapter usually goes for? and where i should buy Link to comment Share on other sites More sharing options...
Drift Motion Posted December 30, 2010 Share Posted December 30, 2010 25ish fredbeans or infamous performance...both on here Link to comment Share on other sites More sharing options...
SBT Posted December 30, 2010 Share Posted December 30, 2010 This is what you need. 3" flat DP flange to 2.5" donut CBE flange. Includes the gaskets for a proper fit...$61.00 plus shipping, but think you can probably get in on FB's holiday discount. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
CB-M3 Posted December 30, 2010 Share Posted December 30, 2010 I assume you need this adapter also if you go aftermarket DP to stock CBE. Link to comment Share on other sites More sharing options...
SBT Posted December 30, 2010 Share Posted December 30, 2010 Yes. Some members have tried it without the adapter, and eventually go to the adapter or to a flat-flange CBE. I've got the opposite problem with a 2.5" COBB DP into a 3" flat-flange CBE. Use the 2.5" donut to 3" flat-flange WBR adapter and new gaskets for mine. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Specbobae Posted December 31, 2010 Author Share Posted December 31, 2010 If i get the dp with no tune, is this going to hurt my engine? before i got my intake i heard the same things ... but nothing has happened yet. i don't live at sea level, im in CO. also i've heard that with my 06 spec b i will need a catless up pipe as well? Link to comment Share on other sites More sharing options...
Specbobae Posted December 31, 2010 Author Share Posted December 31, 2010 its an STI engine, so i dont understand...could it be the STI tune? my friend bought the invidia catless dp for his STI and no tune. no problem Link to comment Share on other sites More sharing options...
jfg22557 Posted December 31, 2010 Share Posted December 31, 2010 If i get the dp with no tune, is this going to hurt my engine? before i got my intake i heard the same things ... but nothing has happened yet. i don't live at sea level, im in CO. also i've heard that with my 06 spec b i will need a catless up pipe as well? ...dude, this is the second ill informed piece of information Ive seen you post up. and thats just today! really, do your research before you put these components on your car with no tune. The intake is undoubtedly causing you to lean out, and WILL kill your motor in time. you dont have an "sti engine" in your car necessarily, you have an EJ255, sti is an EJ257 (slightly different piston shape IIRC), and different turbo, intake manifold, ect. DO NOT PUT THESE COMPONENTS ON YOUR CAR WITHOUT A TUNE, ALTITUDE IS IRRELEVANT. and your buddy with the sti and a downpipe with no tune unfortunately doesnt sound like the brightest bulb in the box either. again man, im really sorry to sound harsh, but your going to regret it when your motor is gone from these mods your installing untuned. Not to mention, an intake is not necessary until stg 3 + power levels, the oem intake snorkel/air box is best up to stg 2 (downpipe + catless up pipe), theres no need for more air flow until you pass that level of modification (aka installing a larger turbo + fuel pump + injectors ect..) were all here to help you, but you really need to just sit down, read, read, research and research some more before you wind up paying dearly. cause your kind of sounding like a vtech kid right now that has now idea what hes doing, having a field day at autozone and slapping sh*t on his car.. Link to comment Share on other sites More sharing options...
m sprank Posted December 31, 2010 Share Posted December 31, 2010 ^+1BILLION, Zillion! Link to comment Share on other sites More sharing options...
ERZperformance Posted December 31, 2010 Share Posted December 31, 2010 are there any mating problems with an invidia downpipe and cobb catback? http://img337.imageshack.us/img337/5290/imgp4177l.jpg Chop your cobb exhaust and weld one of these on JK 3 inch adapter Link to comment Share on other sites More sharing options...
