carguyco Posted February 19, 2010 Share Posted February 19, 2010 Don't read much about the banjo bolt on 2007 LGT....Same problem as the older ones? Not an issue? Is the check/inspect procedure the same? Thanks in advance... Link to comment Share on other sites More sharing options...
Code Posted February 19, 2010 Share Posted February 19, 2010 07 doesn't have the filter. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
Darkness of Death Posted February 19, 2010 Share Posted February 19, 2010 not sure if 07 doesn't - i changed mine out. dont remember if it did or didnt' but you could always check to make sure. Link to comment Share on other sites More sharing options...
RJS5689 Posted February 20, 2010 Share Posted February 20, 2010 07 doesn't have the filter. I thought we all had them, regardless of year... Link to comment Share on other sites More sharing options...
jagcars26 Posted February 20, 2010 Share Posted February 20, 2010 I thought we all had them, regardless of year... I thought the same Link to comment Share on other sites More sharing options...
Code Posted February 20, 2010 Share Posted February 20, 2010 I thought the filter was eliminated with the vf46... "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
scoobydoobie Posted February 21, 2010 Share Posted February 21, 2010 hmmmm Link to comment Share on other sites More sharing options...
Polo08816 Posted February 22, 2010 Share Posted February 22, 2010 I thought the filter was eliminated with the vf46... If there is a TSB for your car regarding a banjo bolt, then you have one. I remember seeing a TSB for my 2008 LGT 5EAT regarding the banjo bolt. Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted February 22, 2010 Share Posted February 22, 2010 I had a recall for my banjo filter Link to comment Share on other sites More sharing options...
RJS5689 Posted February 23, 2010 Share Posted February 23, 2010 Uhm what banjo TSB? Do you mean TSB #02-103-07, because it's near impossible to find anything about it. I can't even find a copy of the TSB anywhere! From what I could find, the TSB said, "The Subaru solution is to decrease the oil change interval by 1/2 to 3750 miles (6,000km) or 3-3/4 months for both the crankcase oil and filter, and inspect the screen and oil supply pipe at every oil change." However, Subaru says this must be the service interval of ALL of their turbocharged vehicles. This is why I assume even the 2007+ vehicles still have them. I had an argument with my dealer over them not checking the banjo bolt on my car. They are actually not required to pull, check and clean it. Link to comment Share on other sites More sharing options...
scoobydoobie Posted February 23, 2010 Share Posted February 23, 2010 Copies of the TSBs can be found here: http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=Info_SubaruOil Link to comment Share on other sites More sharing options...
Catalyst Posted February 23, 2010 Share Posted February 23, 2010 So are people just taking the filter out, or replacing it? "This is an adventure." Link to comment Share on other sites More sharing options...
DrCloud Posted February 23, 2010 Share Posted February 23, 2010 Ugh. The '07 TSB says "for informational purposes only" and the '08 one eliminates that in favor of a "just do this..." approach. I've been having service done at an independent shop (dealerships here are not so good...), and it looks like I need to make sure they're aware of this. HPH Link to comment Share on other sites More sharing options...
