EL34 Posted March 21, 2015 Share Posted March 21, 2015 1997 Outback legacy wagon The windshield washer no longer squirts when I pull back on the lever I pulled the connector to the front washer motor and jumpered directly to the battery. The motor squirts I then hooker a multi meter to the motor connector terminals and then pulled back the wiper lever arm. The voltage goes from zero to under 150 millivolts when pulling on the lever. So I am not getting the full 12 volts to the motor If it was a fuse, I would get zero all the time So the switch itself stopped working I pulled the lower half of the steering column bezel off and had a look. Looks like both levers on the steering wheel are all part on one big assembly and it's not cheap? $482, Yikes Found the image below at parts geek of that assembly I had the same problem on my 89 S10 pickup and so I wired in a button on the dash to squirt the washers. Worked great and was more powerful than the power the puny column switch could deliver I don't think I want to disassemble the steering column and I don't want to pay $400+ for that assembly Looks like I'll be adding a button on the dash for the sooby also unless someone else has got a better idea or the switch can actually be repaired easily? Link to comment Share on other sites More sharing options...
cdr_warsstar Posted March 22, 2015 Share Posted March 22, 2015 I think the wiper stalk can be separated from that assembly. One of the mods I was planning on doing to my 1999 Legacy Outback was swapping the wiper stalk to one that had more intermittent speed settings. I have the part in the garage somewhere, I can get a picture of it later. I need to check and see if I'm still going to use it or not, if not, you're welcome to it. I'll get back to you. Link to comment Share on other sites More sharing options...
EL34 Posted March 22, 2015 Author Share Posted March 22, 2015 Thanks for the offer. If you can get a detailed picture of the actual switch that would be great I could not see the switch itself when I looked at mine I don't want to tear mine all apart unless I am sure I can fix the switch I can fix just about anything if I can get a good look at it Link to comment Share on other sites More sharing options...
cdr_warsstar Posted March 23, 2015 Share Posted March 23, 2015 Here you go. I can get more pics if you like. Now the two holes in the second image have screws that I think are the only things holding it in place. The hardest part is getting them out without removing the steering wheel. I think I took a Phillips bit and a 1/4" wrench and used them as a right-angled screwdriver. You can see the two screws in your first image, to the right of the blue seal. The next hardest thing is fishing the wiring harness back up the steering column. Link to comment Share on other sites More sharing options...
EL34 Posted March 23, 2015 Author Share Posted March 23, 2015 Ah ok thanks. Good to know I can remove that assembly with a 90 degree bit and not remove the steering wheel I still can't tell where the actual mist switch is It looks like it may be on the back of that assembly you are holding I guess I will have to have a go at it and figure it out Thanks for you help on that One thing I noticed in your pics is that it looks like the intermittent circuit is right there I see the relay and a electrolytic capacitor I have been wanting to have a longer intermittent cycle for quite a while It's way too fast on my sooby You can usually increase the value on that capacitor to get longer charge times before the relay triggers One more reason for me to get in that and have a look Link to comment Share on other sites More sharing options...
cdr_warsstar Posted March 24, 2015 Share Posted March 24, 2015 The mist switch must be under the black plastic cover, because the back is just a circuit board. Although, as I was looking to see what car this came out of, I found that the wiper stalk assembly may be different between the '97 and '99 models, even though they are the same gen. Post #7 on: http://forums.nasioc.com/forums/showthread.php?t=559808 Link to comment Share on other sites More sharing options...
EL34 Posted March 27, 2015 Author Share Posted March 27, 2015 I posted a pic of the supposed assembly that fits my sooby in post #1 It has two stalks I was thinking that you had separated the wiper stalk from that assembly I don't think I am going to dig into mine If I break something, I will have to buy that whole assembly and it's very expensive Link to comment Share on other sites More sharing options...
johnegg Posted March 27, 2015 Share Posted March 27, 2015 if you have not yet done it. check at the harness connection in the steering column to make sure it is the switch and not the wiring after the switch. second, this is the first time i have heard of this part failing. buy a used one from http://www.car-part.com sort by zip code to see what is close, then by price to see what is cheap. there are lots of these out there in good used condition just sitting around. there is no demand for them. tip, if you get one from a GT (maybe an outback too) you will have adjustable variable intermittent wipers. i think. finally, someone in the VA / NC area bought one from the dealer for full price, and just used the clock spring . they were trying to sell the rest of it for $100. they were trying for over a year? they may still be. but i have not been keeping track of the craigslist ads recently. good luck. Link to comment Share on other sites More sharing options...
cdr_warsstar Posted March 28, 2015 Share Posted March 28, 2015 I posted a pic of the supposed assembly that fits my sooby in post #1 It has two stalks I was thinking that you had separated the wiper stalk from that assembly Yeah, my bad. I was thinking that the assemblies did come apart since they did on mine and they're the same gen. Link to comment Share on other sites More sharing options...
EL34 Posted March 30, 2015 Author Share Posted March 30, 2015 Thanks for the info all I have not had time to get back on this yet If I solve this, I will post back Link to comment Share on other sites More sharing options...
EL34 Posted April 6, 2015 Author Share Posted April 6, 2015 A couple days ago, it decided it was going to squirt again. Then yesterday it decided it was not gonna squirt and stopped working again Have not had time to dig into the column yet Link to comment Share on other sites More sharing options...
