roundthirteen Posted October 28, 2012 Share Posted October 28, 2012 Probably asked before but is there any advantages to keeping it on? Advantages to removing it? How about after I change out the stock TMIC and BPV for something a little better? My car's not a sleeper it's a hibernator. http://pure-tuning.com Link to comment Share on other sites More sharing options...
iNVAR Posted October 28, 2012 Share Posted October 28, 2012 you're right, it's been asked. search. engine cover is supposed to help make a better seal with the hood scoop and the tmic so that air goes where it's supposed to: through the tmic, not around it. http://www.google.com/#hl=en&tbo=d&output=search&sclient=psy-ab&q=engine+cover+removal+site:legacygt.com&oq=engine+cover+removal+site:legacygt.com&gs_l=hp.3...999.4420.0.4561.38.18.0.0.0.0.438.4012.0j7j7j1j2.17.0.les%3Beqn%2Ccconf%3D1-2%2Cmin_length%3D2%2Crate_low%3D0-035%2Crate_high%3D0-035%2Csecond_pass%3Dfalse%2Cnum_suggestions%3D2%2Cignore_bad_origquery%3Dtrue..0.0...1c.1.1AELx0UMszQ&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.&fp=5a9b8f6711c43ac8&bpcl=35466521&biw=1280&bih=827 Link to comment Share on other sites More sharing options...
famaya26 Posted October 28, 2012 Share Posted October 28, 2012 Well if you want your car to explode then go ahead remove it In all seriousness it helps the stock IC operate more efficiently. You can hack it up when installing an AVO TMIC and remove if you go with a FMIC. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 28, 2012 Share Posted October 28, 2012 I've had mine off since a couple of day's after I bought my 2005 wagon in late June 2004 I took it off one day to look under it and I lost one of those plastic clips, and left it off ever since. I removed the one from my 09 Spec B too. I want to see the engine when I open the hood, not some piece of plastic. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
sko Posted October 28, 2012 Share Posted October 28, 2012 Mine didn't have one when it got to me... >_< ...so dirty... engine... so... dirty... Link to comment Share on other sites More sharing options...
lee07 Posted October 29, 2012 Share Posted October 29, 2012 Don't think there are any + or -'s. I May be wrong here but sti's and wrx's don't have a cover I keep mine on so when people want to see what's under the hood it looks stock, even though its not Link to comment Share on other sites More sharing options...
Nrw Posted October 29, 2012 Share Posted October 29, 2012 Don't think there are any + or -'s. I May be wrong here but sti's and wrx's don't have a cover I keep mine on so when people want to see what's under the hood it looks stock, even though its not The WRX and STI splitter also fits up against the tmic unlike the LGT one. Link to comment Share on other sites More sharing options...
Rooster Posted October 30, 2012 Share Posted October 30, 2012 The WRX and STI splitter also fits up against the tmic unlike the LGT one. This ^ Removing the cover isn't going to make anything explode, but it will hurt the efficiency of the intercooler, and therefore power. So removing it isn't recommended. Link to comment Share on other sites More sharing options...
sko Posted October 30, 2012 Share Posted October 30, 2012 Did the 2.5i come with an engine cover? Link to comment Share on other sites More sharing options...
bigleben Posted October 30, 2012 Share Posted October 30, 2012 Did the 2.5i come with an engine cover? Do 2.5i have an intercooler?? Link to comment Share on other sites More sharing options...
Rooster Posted October 30, 2012 Share Posted October 30, 2012 I don't know if the 2.5i had one or not, but with no TMIC, it doesn't matter. If you go to a front mount, feel free to remove the thing. Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted October 30, 2012 I Donated Too Share Posted October 30, 2012 Did the 2.5i come with an engine cover? :eek: Link to comment Share on other sites More sharing options...
roundthirteen Posted October 30, 2012 Author Share Posted October 30, 2012 Maybe I'll throw it back on until I get a better TMIC, now I have to get new bolts for it..... It's SO UGLY! My car's not a sleeper it's a hibernator. http://pure-tuning.com Link to comment Share on other sites More sharing options...
I Donated Too luchadorjose Posted October 30, 2012 I Donated Too Share Posted October 30, 2012 I used my engine cover without the pop-its ever since I bought the car. because of where it sits and how the splitter presses on it, it doesn't go anywhere Link to comment Share on other sites More sharing options...
Nubie Posted October 30, 2012 Share Posted October 30, 2012 It sounds like the cover bothers you as much as it bothered me. Removed it, but kept the functionality. Also It doesnt have to be as involved as I showed there, I can explain if you want to do it. Or i guess I can edit that thread later. http://legacygt.com/forums/showthread.php/engine-cover-relocation-190220.html Link to comment Share on other sites More sharing options...
WhiteGirl Posted October 31, 2012 Share Posted October 31, 2012 Took mine off didn't see and noticeable changes... Link to comment Share on other sites More sharing options...
I Donated Too luchadorjose Posted October 31, 2012 I Donated Too Share Posted October 31, 2012 Took mine off didn't see and noticeable changes... Are you logging IAT's, IAM, or timing compensation? It's only a matter of a handful of horsepower in certain situations. "Butt dyno" isn't a valid tool to say you didn't notice any change Link to comment Share on other sites More sharing options...
Rooster Posted October 31, 2012 Share Posted October 31, 2012 If I get bored in the next few days maybe I'll do a bit of logging with and without it to see how much of a difference it makes. I'm kind of digging the mod to attach it to the hood, since I'm very much not a fan of engine covers. Only reason I still have it is to keep that intercooler working as efficiently as possible. Link to comment Share on other sites More sharing options...
iNVAR Posted October 31, 2012 Share Posted October 31, 2012 You can't monitor IAT to determine TMIC efficiency. The IAT sensor is located near the airbox, before the TMIC. Link to comment Share on other sites More sharing options...
Rooster Posted October 31, 2012 Share Posted October 31, 2012 True, but you can monitor load. If the intercooler is being significantly less efficient, the air will be less dense after it, therefore less load at the same boost. (Unless I'm crazy, feel free to correct me). Not as nice at looking at a temperature, but really a bit more relevant to real world performance anyway. Link to comment Share on other sites More sharing options...
Rooster Posted November 4, 2012 Share Posted November 4, 2012 Alright, so I actually tested this today by monitoring load for 3 pulls (one with the cover, one without, and another with). Conclusion: Doesn't matter. Max load didn't change by more than .02g/rev between any of the runs, and looks to be within the error I'd anticipate. So, even though I said it should theoretically make a difference, it doesn't look like it does in the real world, at least in the conditions I was in. Link to comment Share on other sites More sharing options...
