Vengeance68 Posted October 14, 2015 Share Posted October 14, 2015 I know that eventually I will need a new SB however, for now my 187k mile LGT is still rockin it at over 27mpg on a OTS Stg2 tune. http://images.tapatalk-cdn.com/15/10/13/87a03ed76e0badd29acea7f5f73360a6.jpg Bringing the pain since 1968 Link to comment Share on other sites More sharing options...
Merc6 Posted October 14, 2015 Share Posted October 14, 2015 At 1st I'm like pic for post whore but I noted the MPG. Besides turnpike, my mpg stayed 17-19 mpg. My Legacy replaced a 4200 lb premium fuel only V8 land yacht so MPG wasn't a hit for me. I do have envy as I barely made it to 90K on SB 1 and turbo 2 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Max Capacity Posted October 14, 2015 Share Posted October 14, 2015 Did you buy it new ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Vengeance68 Posted October 14, 2015 Author Share Posted October 14, 2015 Did you buy it new ? No, I bought it last year. I test drove 20+ Subies before I found this LGT. Bringing the pain since 1968 Link to comment Share on other sites More sharing options...
Lafta Posted October 14, 2015 Share Posted October 14, 2015 How hard (or gently do you drive it? Link to comment Share on other sites More sharing options...
wesleyCrowbar Posted October 14, 2015 Share Posted October 14, 2015 Giving me hope :') I just hit 112k on stage 1. Link to comment Share on other sites More sharing options...
Vengeance68 Posted October 14, 2015 Author Share Posted October 14, 2015 How hard (or gently do you drive it? I don't thrash it by any means however, I do drive in a spirited manner from time to time. I run on a Cobb OTS Stg2 with; Catless dp Catback exhaust Rebuilt JmP VF40 Bulletproof TMIC kit Various suspension mods Bringing the pain since 1968 Link to comment Share on other sites More sharing options...
Lafta Posted October 14, 2015 Share Posted October 14, 2015 Reckon the JmP unit is the key contributor to it's longevity? Or more so the non-thrashing, and or TLC? Or, the Cobb AP ? Orrrrr.....?? I ask, well because it seems a whole lot of folk's turbos are going ka-pow, and I don't want to be in that group. 60k gently driven miles, add in the occasional spirited pull, 3k mi. OCI, with AP. Anyone please? Thank you. Link to comment Share on other sites More sharing options...
Vengeance68 Posted October 14, 2015 Author Share Posted October 14, 2015 Reckon the JmP unit is the key contributor to it's longevity? Or more so the non-thrashing, and or TLC? Or, the Cobb AP ? Orrrrr.....?? I ask, well because it seems a whole lot of folk's turbos are going ka-pow, and I don't want to be in that group. 60k gently driven miles with AP. Anyone please? Thank you. John and I have spoken about this. His theory, and I agree, are the ones who have issues are either driving their cars hard and/or have modified beyond a reasonable power range. Bottom line, if you treat your car like a race car you will have race car issues. If you can afford that then no problem but, I don't think most people are set up financially to deal with that paradigm. I know I am not. When I bought my LGT I had compression and leak-down tests done, R&R'd all seals and gaskets, removed banjo bolt filters, etc... I R&R'd the turbo due to a suspicion mine was swapped/stolen at one of the shops I had it in. Basically, if you take care of your equipment it will take care of you. Of course there are always exceptions. I have most of my fun in corners... I may not be the fastest Subie on a straight away but she corners like a slot car now.[emoji12] Bringing the pain since 1968 Link to comment Share on other sites More sharing options...
Covious Posted October 14, 2015 Share Posted October 14, 2015 I wouldn't doubt its possible, but do the math when you fill up. Between my 05 LGT and a '14 focus ST I had, neither mpg gauge has been accurate. My LGT tells me my average is 25mpg (I reset trip A odometer every fill up), but when i do the math at the pump , its closer to 21.5-22mpg Glad your high-miler is treating you well ! Link to comment Share on other sites More sharing options...
Silinc3r Posted October 14, 2015 Share Posted October 14, 2015 No, I bought it last year. I test drove 20+ Subies before I found this LGT. Bringing the pain since 1968 Did you buy it from a member here? Reason ask is, how do you know the engine hasn't been replaced? If all original sweet Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
Max Capacity Posted October 14, 2015 Share Posted October 14, 2015 Did you buy it from a member here? Reason ask is, how do you know the engine hasn't been replaced? If all original sweet Glad I wasn't the one to ask this...not that I didn't think about it... My original propeller shaft and both rear axles are still going great at 214,000 miles. All the other moving parts have been changed, not bad for an 11year 4 month old car...LOL Well it does still have the same valves and cams in the engine so I guess I have to include them in, original. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Merc6 Posted October 14, 2015 Share Posted October 14, 2015 Yeah a rebuilt turbo before it fails is key. Catching the banjos before it clogs the lines is key. Deleting the cat in the up is also key. Checking oil.... You get where I'm going with this. Sent from my iFail using Tapatalk App 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
BMG905 Posted October 17, 2015 Share Posted October 17, 2015 Wish I could get mileage like that, my bone stock LGT delivers 21.5 in regular & spirited driving. I've had the banjo fittings changed several times starting at 60k miles, so far so good. Link to comment Share on other sites More sharing options...
Merc6 Posted October 18, 2015 Share Posted October 18, 2015 Wish I could get mileage like that, my bone stock LGT delivers 21.5 in regular & spirited driving. I've had the banjo fittings changed several times starting at 60k miles, so far so good. How is oil consumption? 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
