Perfect Dark Posted July 7, 2008 Share Posted July 7, 2008 So I think I finally have all of my mechanical issues behind me, boost seems to be holding well and the car is running great. The only thing left to determine is why we can't seem to make the power that the turbo is capable of. I am currently using the stock LGT pill...what should I be using? I have one from an 06 WRX that I could use but I want to make sure it will be the right one. I have logs that want to put up but not sure how, so I am willing to PM them if anyone would like to take a look-see. Thanks! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 7, 2008 Share Posted July 7, 2008 Take a log of 3rd gear, 2000-7000 rpm. re-name the log with a .pdf extension post up here as an attachment Are you hitting target boost? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Perfect Dark Posted July 7, 2008 Author Share Posted July 7, 2008 Thanks, I will get them up asap. I honestly don't know enough about the data to comment, so I will let them speak for me. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted July 7, 2008 Share Posted July 7, 2008 It depends upon a lot of factors. I keep all three generic sizes on hand: 0.8, 1.0, and 1.2 mm. Start with the largest pill. If WGDC is > 70%, go down to the next smaller size. In general, the stock LGT restrictor pill is too large. It is approximately 1.25 mm. If you have the WG actuator set to open at 8 psi, then you should go with a 1.0 mm pill. Set your WGDC max table to 0 and do a 3rd gear log. Plot MRP vs rpm. The kink in the plot is where the WG opened. I usually set it to between 8 to 10 psi depending upon the turbo. You definitely want the wastegate to be seated when it is closed. If you tune your boost and you see a kink in boost at high rpm, then you'll need a higher WG preload due to EGBP opening the wastegate. Unless your turbo was overported, this usually isn't a problem. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted July 7, 2008 Share Posted July 7, 2008 BTW, if you swap restrictor pill, you will need boost control completely retuned for best performance. You cannot just swap out restrictor pills. Link to comment Share on other sites More sharing options...
Perfect Dark Posted July 7, 2008 Author Share Posted July 7, 2008 http://www.thelinkup.com/SharedPage.aspx?vpath=kgh1ygi3yfp7 Link to comment Share on other sites More sharing options...
Perfect Dark Posted July 7, 2008 Author Share Posted July 7, 2008 Sorry about that guys, the link is working now. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted July 7, 2008 Share Posted July 7, 2008 I don't think the restrictor pill will help you. BTW, what is the ecu atmospheric pressure and what is the ambient temperature? Are you using an aftermarket intake? Link to comment Share on other sites More sharing options...
Perfect Dark Posted July 7, 2008 Author Share Posted July 7, 2008 Ambient temp was around 80F, no aftermarket intake...no idea of the ecu pressure. What would be restricting the boost then? Link to comment Share on other sites More sharing options...
Airboy Posted July 7, 2008 Share Posted July 7, 2008 I don't think the restrictor pill will help you. BTW, what is the ecu atmospheric pressure and what is the ambient temperature? Are you using an aftermarket intake? The ambient pressure is ~12.9psi (~3500') Link to comment Share on other sites More sharing options...
Perfect Dark Posted July 8, 2008 Author Share Posted July 8, 2008 The ambient pressure is ~12.9psi (~3500') Thankyou Airboy, wasn't sure what that was. If I am missing any info it would be great if you could help fill in the blanks. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted July 8, 2008 Share Posted July 8, 2008 Whoops. I didn't see that you had logged Patm. Your boost and load are not that unusual given that you are at a slightly higher altitude. You can try raising your boost target by 1 psi across the board and see if your acceleration gets better (or worse). The reason that I said that a restrictor pill won't help you is that you are not yet bumping into the limit. Don't reset your ecu or reflash it. After you've driven around a bit, try merchgod's learinng viewer and post up the CSV file. Link to comment Share on other sites More sharing options...
Airboy Posted July 8, 2008 Share Posted July 8, 2008 Whoops. I didn't see that you had logged Patm. Your boost and load are not that unusual given that you are at a slightly higher altitude. You can try raising your boost target by 1 psi across the board and see if your acceleration gets better (or worse). The reason that I said that a restrictor pill won't help you is that you are not yet bumping into the limit. Don't reset your ecu or reflash it. After you've driven around a bit, try merchgod's learinng viewer and post up the CSV file. The WGDC that was logged is pretty much the limit set in Max WGDC table and the boost target is slightly above logged values. I guess it is rolling off a little like my VF-39 did when I had the stock BCS. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted July 8, 2008 Share Posted July 8, 2008 The WGDC that was logged is pretty much the limit set in Max WGDC table and the boost target is slightly above logged values. I guess it is rolling off a little like my VF-39 did when I had the stock BCS. Yes, but the OP was asking why he couldn't increase the boost. My point is that he can (or you can) by increasing the MAX WGDC table to the MAX global WGDC (90%). I would only change the pill to a smaller pill if WGDC was at 90% and you still can't hit target boost. Link to comment Share on other sites More sharing options...
Perfect Dark Posted July 18, 2008 Author Share Posted July 18, 2008 Just thought I would update the thread. We installed the WRX pill and it seemed to do the trick. Went from 17ish PSI to around 19 PSI. I appreciate all the responses though guys, thanks! Link to comment Share on other sites More sharing options...
