Clunk while turning
WYO_LGT05
Every time i take a corner while acceleration i hear a repeated clunking noise from the rear driver side. also if launching i hear the same noise. is this my rear diff????:confused: this does not happen at higher speeds, only from a beginning roll on turns and launches.
I have a 05 5eat LGT, Full catless exhaust, cobb tuner and a spt intake
p.s. i know launching is bad....but its fun!!
I just posting my issues with similar problem:
Symptoms: popping and jerking, seemingly coming from the rear, only at low speed turns under load. I could coast through a turn without problem, but threading the throttle resulted in popping sound. No popping under moderate accelleration in a straight line, but hard acceleration resulted in popping.
results: BUSTED REAR DIFF!!!! Park it before you blow the tranny like I did.
