Subtleamuzement Posted September 15, 2012 Share Posted September 15, 2012 I was driving my outback today and after I parked the car kept beeping and I couldn't figure out why. It turned out that the ignition cylinder will only go as far as the accessory position and wont go to the lock position. I am going to get a new key made tomorrow but in the mean time, will my car battery drain out tonight? The radio is off and no lights will turn on so I think I am ok but I am not 100% Any thoughts? Link to comment Share on other sites More sharing options...
purebluedoor Posted September 15, 2012 Share Posted September 15, 2012 should be fine if you can get the key back to off, and out if you goto a subie dealer w your title theyll usually cut you a perfect new key. ive had a 3rd party cut subie keys and theyre never as good Link to comment Share on other sites More sharing options...
twisty Posted September 17, 2012 Share Posted September 17, 2012 i had this happen once in a friends car. turns out i was so used to my 5mt trans, i didnt remember to drop his into park. sat there for 45 minutes until one of my buds told me it wasnt in park... ive had 5 keys made for my car so far, one of them works well enough to use so far. Link to comment Share on other sites More sharing options...
silentguy Posted September 24, 2012 Share Posted September 24, 2012 Have you tried jiggling the steering while moving the key. Has worked for me in the past with other cars. Link to comment Share on other sites More sharing options...
Frank B Posted September 24, 2012 Share Posted September 24, 2012 Try pushing the key in deeper while you turn it. Some of the older models are made that way so you don't lock the wheel by accident while the car is moving. In an emergency like if the throttle sticks, turning off the ignition will kill the engine, but you still need steering. Link to comment Share on other sites More sharing options...
Subtleamuzement Posted April 23, 2013 Author Share Posted April 23, 2013 Thanks for the potential ways to fix this problem. At the point I am still having problems with it and I am taking it to the dealer in 2 days. I took it to a local shop and they told me I needed a new key cylinder at the price of $300. So, I will see what my options are and if worst comes to worst Ill just buy one and put it in myself. Link to comment Share on other sites More sharing options...
Zues Marine Posted April 23, 2013 Share Posted April 23, 2013 is this an Auto or Manual? Link to comment Share on other sites More sharing options...
Subtleamuzement Posted April 24, 2013 Author Share Posted April 24, 2013 It's a manual I have jiggled and pushed they key and it still won't budge. I am goin to try Teflon spray if the dealer key wont work. Link to comment Share on other sites More sharing options...
Subtleamuzement Posted April 26, 2013 Author Share Posted April 26, 2013 PROBLEM SOLVED!!!! YES! The Sube dealer cut a new key and it worked. Very pleased at the moment. The key was $12 and they washed it. Link to comment Share on other sites More sharing options...
Hemingway Posted April 26, 2013 Share Posted April 26, 2013 Congratulations on the cheap fix! Link to comment Share on other sites More sharing options...
