RHDsubaru Posted January 17, 2013 Share Posted January 17, 2013 bought a used trany with no front axle shafts,is this normal , if so how does diff side retainers come off. Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 17, 2013 Share Posted January 17, 2013 The axles have splines that slide into the diff. On first and second gens the spline is attached to the diff and the axles fit onto the splines and are secured with a spring pin. The later subaru axles have splines that are integrated into the axles and they slide into the diff. I was removing an axle on my first gen and I accidentally pulled the spline out of the diff. I just popped it back in with no problems after talking to a subaru tech. What year trans did you purchase? You'll probably have to locate a couple of splines. Link to comment Share on other sites More sharing options...
RHDsubaru Posted January 19, 2013 Author Share Posted January 19, 2013 1996 Link to comment Share on other sites More sharing options...
RHDsubaru Posted January 19, 2013 Author Share Posted January 19, 2013 Also the side retainers do they un thread or pop off after you remove the bolt at the top & clip(on the outside of diff. case. Link to comment Share on other sites More sharing options...
