Rely18 Posted October 7, 2006 Share Posted October 7, 2006 don't know if anyone else has experienced this issue, did a search but didn't find similar symptoms... i was on the highway last night and decided to set the cruise at 80mph - no traffic, good visibility. i am sure i have done this before on the same highway, with no issues. well i noticed the car slowing down, and the "set" light was off. the cruise light itself was still on. i accelerated and hit resume and the car cruised again at 80mph. 10 seconds later, it began to slow again. i repeated this 3 times to make sure that i wasn't bumping the cancel or off buttons, and it continued to disable itself. i turned off and on the cruise control, slowed down to 75mph and tried again. this time it worked for a few minutes but then automatically started shutting off like before. i am not getting any CEL or anything like that. there was no significant surging and i have never experienced this before under the same cirucmstances. i noticed it was happening more on slight downgrades, but a few times even on flat stretches. i'm confused? Link to comment Share on other sites More sharing options...
johnAWD Posted October 7, 2006 Share Posted October 7, 2006 Were you in 4th gear? I experienced something similar once when I forgot to shift into 5th. Link to comment Share on other sites More sharing options...
Rely18 Posted October 7, 2006 Author Share Posted October 7, 2006 i was in 5th. 5MT 18k miles i would assume it was a speed related thing, but i am sure i have done this multiple times before without any problems. Link to comment Share on other sites More sharing options...
johnAWD Posted October 7, 2006 Share Posted October 7, 2006 Ok - just checking. FWIW, I can't set the cruise above 89 on my 05 mt. Not that I would... Link to comment Share on other sites More sharing options...
Max25 Posted October 16, 2006 Share Posted October 16, 2006 I just noticed that I am having the same issue. The problem seams to occur between 75 and 80 mph. It goes for like 15 seconds then shuts off. I am running Stage 1. Anyone have any ideas? Link to comment Share on other sites More sharing options...
jlce88 Posted October 16, 2006 Share Posted October 16, 2006 Would like to know also as my friend with a manual 2.5i has the same issue. I've experienced that issue with my Mustang and it was caused by a vibrating clutch pedal. It was vibrating against the switch that cuts the cruise off when you push the clutch pedal in. His wasn't this issue, but maybe one of yours is? Link to comment Share on other sites More sharing options...
ilh Posted October 16, 2006 Share Posted October 16, 2006 It could be the neutral sensor on the transmission. A number of those have been replaced on LGTs. Search for it. Someone had a fix involving washers or somesuch if you don't want to go to the dealer. --Lee Link to comment Share on other sites More sharing options...
05LegacyGT330Ci Posted October 16, 2006 Share Posted October 16, 2006 Had that happen a few times, twice mentioned it to the dealer, neither time could they figure it out. '05 Black Legacy GT Wagon 5-spd '02 Topaz/Black 330Ci 5-spd Drift Ryder's School of Rally Arts, coming to an Australia near you. Link to comment Share on other sites More sharing options...
Fast Wagon Posted October 17, 2006 Share Posted October 17, 2006 I had the same problem. The dealership had to re-flash my computer. There is a service bulletin on this issue. Search in the warranty section for cruise control disengaging. Link to comment Share on other sites More sharing options...
robinlsb Posted October 17, 2006 Share Posted October 17, 2006 I had the same problem. The dealership had to re-flash my computer. There is a service bulletin on this issue. Search in the warranty section for cruise control disengaging. +1, fixed by dealer "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
DukeTrout Posted October 17, 2006 Share Posted October 17, 2006 Yeah, good advice here. I was going to mention that the cruise disengage on the clutch is very sensitive. If I forget and just brush the clutch with sideways pressure, it shuts off the cruise. Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
Bob N Posted October 18, 2006 Share Posted October 18, 2006 +1, fixed by dealer +2. Dealer just fixed earlier this month. A reflash should do it. Link to comment Share on other sites More sharing options...
gfxdave99 Posted October 18, 2006 Share Posted October 18, 2006 Yeah not a speed issue, cruise works all the way up to 87.5 If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
mccorry Posted February 18, 2008 Share Posted February 18, 2008 Mine just started doing this.... seems to do it when I go uphill for some reason... Link to comment Share on other sites More sharing options...
mojosvt Posted July 28, 2008 Share Posted July 28, 2008 Bump to the top. My just started doing this. I have a tune on the car, so getting a re-flash really isn't an option. Anybody else have this issue, or a fix. Like where the clutch disable switch is located? Link to comment Share on other sites More sharing options...
CwhillVT Posted July 28, 2008 Share Posted July 28, 2008 I have had this happen to me a few times- maybe 4 or 5. If it starts to happen more frequently I might investigate. Interesting to know that it isnt just me. Link to comment Share on other sites More sharing options...
rallysquirrel Posted July 28, 2008 Share Posted July 28, 2008 What you can do is set cruise at 87mph then increase cruise speed by using the cruise button. This will allow you to set a higher than 90mph cruise speed. Has worked for me in the past when driving 500 miles + in a day. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2008 Share Posted August 13, 2008 Just spoke with the dealer today about this problem, cruise dropping out. He said, oh yea with 5-speeds it has to do with the neutral safety switch, washer thickness. They have fixed a few of them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
