ctbill Posted September 30, 2015 Share Posted September 30, 2015 I have a 2005 legacy gt, ran good until turbo blew. I replaced turbo then car started to lag a little at around 1500 -2500 rpm. Progressively got worse. Only 1000 miles on new turbo. Then no low-end power. Brought to performance shop had bad up and down pipe installed new still no low end power... anybody that can help.. car looks beautiful and car it self is in great shape hate to junk it. But I bought for 3500$ put 2500 in it between turbo and pipes. Shop said 5000$ for replacement motor with 25000 miles. .. help please thanks for reading. Link to comment Share on other sites More sharing options...
FJuan Posted September 30, 2015 Share Posted September 30, 2015 Did you have the car re-tuned after the new turbo was installed? You'll need to run some data logs and see where the problem is, it could be an air/fuel issue and just needs to be re-tuned. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Dujo Posted September 30, 2015 Share Posted September 30, 2015 http://legacygt.com/forums/showthread.php/turbo-failure-wiki-173358.html Link to comment Share on other sites More sharing options...
compsurge Posted September 30, 2015 Share Posted September 30, 2015 Do you have any boost? It sounds like your up pipe cat was bad and damaged the turbo. See if you can spin it by hand by removing the downpipe. Link to comment Share on other sites More sharing options...
ctbill Posted October 1, 2015 Author Share Posted October 1, 2015 yeah have plenty of boost. no low end power. like floor it and nothing. above 3000 rpm plenty of power Link to comment Share on other sites More sharing options...
compsurge Posted October 1, 2015 Share Posted October 1, 2015 Look for vacuum leaks and datalog. Sounds like a lot of pulled timing. Link to comment Share on other sites More sharing options...
FJuan Posted October 1, 2015 Share Posted October 1, 2015 Yup, data log will show if there is timing or air/fuel issues. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Merc6 Posted October 1, 2015 Share Posted October 1, 2015 *Elephant in the room* When we say turbo was replaced, was this a "I took the blown one out and dropped the new one in it's place" situation? As in no parts internally were cleaned and no banjo filters inspected? 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
compsurge Posted October 1, 2015 Share Posted October 1, 2015 Shhhh. Don't let them in on the dirty little secret. Link to comment Share on other sites More sharing options...
BrianEarlSpilner Posted October 1, 2015 Share Posted October 1, 2015 What they're getting at... if the turbo blew before you replaced it, most likely it sent metal particles into your engine. Now you may need a new short-block due to the unseen damage. I wouldn't put a used motor in your car for that price. While that may not be your issue, it seems to be a recurring problem here after turbo failures. Link to comment Share on other sites More sharing options...
LeggySue Posted October 1, 2015 Share Posted October 1, 2015 maybe avcs ? not really a under the hood guy but i have 06 sti that is suffering from early boost problems due to bad avcs sensors. Link to comment Share on other sites More sharing options...
FJuan Posted October 1, 2015 Share Posted October 1, 2015 Anytime this issue pops up, it's best to run a data log to see what the possibililties are. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Brian2.5GT Posted October 2, 2015 Share Posted October 2, 2015 Check out east coast swappers they have good prices on engine swaps. When my turbo imploded 35k miles ago at 70k miles I had the engine flushed twice. I haven't had any issues. Did you flush the motor? $5k is a lot of ging to spend broh... Link to comment Share on other sites More sharing options...
JmP6889928 Posted October 2, 2015 Share Posted October 2, 2015 yeah have plenty of boost. no low end power. like floor it and nothing. above 3000 rpm plenty of power I would hazard a guess that your first turbo grenaded? If so, then all of what has been said here is truth. If it self destructed and broke the shaft or was slamming on the housings, metal has most definitely been introduced into the engine. If you caught it in time and didn't drive it at all after it blew, several flush oil changes may do the trick. If not, then you are on borrowed time. With that being said and assuming that you have done the flushes and the engine is actually healthy, you most likely have several things going on at once. I would certainly check for boost leaks as that's a good place to start. TMIC tanks can leak easily, TB hose can leak easily, BPV can leak easily, TMIC to turbo connection is always a leak point unless measures have been taken in advance, and ALL of the vacuum hoses can leak easily. Each and every hose needs to be zip tied in place to prevent it from popping off. I also would check for exhaust leaks as if there is a leak pre turbo, it will definitely affect the spool and from your description of late boost, I would believe that could certainly be the culprit too. Listen for a sput sput or a whistle and wet your hands and feel around all of the flanges at every connection and see if you feel exhaust escaping. Good luck with it. If you do end up needing a new short block/engine rebuild, there are many with solid experience on here that I'm sure will be willing to help you, me included. Don't take any shortcuts and don't take anything for granted. When the car is correct, it will be the coolest car you've ever owned and the most fun too. It's worth the work. Link to comment Share on other sites More sharing options...
