gimpydingo Posted July 3, 2013 Share Posted July 3, 2013 Just got my Tactrix 2.0 just in time to do some logging over the long weekend. Which SI mode should I be in when logging, S#? Thanks! Link to comment Share on other sites More sharing options...
fahr_side Posted July 3, 2013 Share Posted July 3, 2013 What are you collecting data for.. what's the purpose of the logs? Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
gimpydingo Posted July 3, 2013 Author Share Posted July 3, 2013 A couple of things. Checking for any potential issues ( I do have some odd tranny/shifting issue between 2nd and 3rd, which may be caused by something else, and obv any other issues) and 2nd once I have a picture of how the car is running, looking to get a stage 1 flash. Then save up for some stage 2 parts, etc.... Link to comment Share on other sites More sharing options...
fahr_side Posted July 3, 2013 Share Posted July 3, 2013 Well, if you're just fishing around in general, check the box for Si Drive position in the switches tab and log a wide range of driving conditions. Have you taken an LV yet? It's a lot easier to understand than long logs of you're not sure what, when you don't really know what you're looking for. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
gimpydingo Posted July 3, 2013 Author Share Posted July 3, 2013 Nope, just got it last night. I am planning to take a LV, which I meant when saying logging, over this long weekend. Any tips? I've found some info in other threads, but anything I should look out for or and tips are more than welcome. Link to comment Share on other sites More sharing options...
fahr_side Posted July 3, 2013 Share Posted July 3, 2013 Read the sticky on LV over at Romraider.com first, then just post your LV here if you like. It's easier to explain it to you with a screenshot to look at, if it doesn't immediately make sense. There are tutorials over there on how Subaru handles knock control and closed-loop fueling which are excellent primers. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
gimpydingo Posted July 3, 2013 Author Share Posted July 3, 2013 awesome, thanks! Link to comment Share on other sites More sharing options...
chimera Posted July 4, 2013 Share Posted July 4, 2013 S# If you're logging in a dumbed down 'I' mode, you're not covering all bases. The turbo hardly even kicks in in 'I' mode. Everything goes up a level of performance in S# so log in that mode. Link to comment Share on other sites More sharing options...
