kiyanichenko Posted May 11, 2007 Share Posted May 11, 2007 why did Subaru start making plastic intake manifold on the legacy and 08 wrx's? Link to comment Share on other sites More sharing options...
BOXRPWR Posted May 11, 2007 Share Posted May 11, 2007 $$$ Link to comment Share on other sites More sharing options...
praedet Posted May 11, 2007 Share Posted May 11, 2007 Better flow, better heat charachteristics... Link to comment Share on other sites More sharing options...
crash Posted May 11, 2007 Share Posted May 11, 2007 $$$ Better flow, better heat charachteristics... I'm sure it was a combination of the 2 Link to comment Share on other sites More sharing options...
fzanetti Posted May 11, 2007 Share Posted May 11, 2007 More the first reason than the second I am sure... Not easy to sell a 32K legacy these days!!!! Each and every penny counts!!! Flavio Zanetti Boston, MA Link to comment Share on other sites More sharing options...
dskelto Posted May 11, 2007 Share Posted May 11, 2007 Weight Reduction? Link to comment Share on other sites More sharing options...
Knight705 Posted May 12, 2007 Share Posted May 12, 2007 plastics do also have better heat reflection than metal. which would heat soak like nothing Link to comment Share on other sites More sharing options...
-TT- Posted May 12, 2007 Share Posted May 12, 2007 also, once metal heats up it retains the heat for much longer Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted May 12, 2007 Share Posted May 12, 2007 not to mention that it is probably easier to produce, saving time, as well as money. Lighter weight can't hurt much on an engine forward of the front wheels, either. Link to comment Share on other sites More sharing options...
kiyanichenko Posted May 12, 2007 Author Share Posted May 12, 2007 the metal manifold isn't that much heavier than the plastic one, is it? Link to comment Share on other sites More sharing options...
-TT- Posted May 12, 2007 Share Posted May 12, 2007 SOLID metal vs. plastic? which do you think is much lighter? Link to comment Share on other sites More sharing options...
kiyanichenko Posted May 12, 2007 Author Share Posted May 12, 2007 SOLID metal vs. plastic? which do you think is much lighter? ya i know, but its not that much heavier that it would make a difference in cars acceleration, top speed, or handling. And wouldn't it be cooler when the engine is running? Link to comment Share on other sites More sharing options...
-TT- Posted May 12, 2007 Share Posted May 12, 2007 ya i know, but its not that much heavier that it would make a difference in cars acceleration, top speed, or handling. And wouldn't it be cooler when the engine is running? Depending on ambient air temperature and the speed at which the vehicle is traveling (and the airflow produced as a result of the speed) it can possibly be cooler, but the average daily driver is driven in stop-and-go traffic which negates this point. The handling is affected by ANY weight in front of the axle. it may not be blatantly noticeable, but it makes a difference. Link to comment Share on other sites More sharing options...
kiyanichenko Posted May 12, 2007 Author Share Posted May 12, 2007 ya i don't doubt it Link to comment Share on other sites More sharing options...
kiyanichenko Posted May 12, 2007 Author Share Posted May 12, 2007 so there is no point of swapping an sti manifold into a legacy? Link to comment Share on other sites More sharing options...
Knight705 Posted May 12, 2007 Share Posted May 12, 2007 unless it is bigger(ie more airflow) i don't think it would be useful. Link to comment Share on other sites More sharing options...
NSFW Posted May 12, 2007 Share Posted May 12, 2007 SOLID metal vs. plastic? which do you think is much lighter? But they're not solid, they're quite hollow. Link to comment Share on other sites More sharing options...
mccorry Posted May 12, 2007 Share Posted May 12, 2007 Me thinks it was done for weight reduction, MPG improvements, power improvements, and cost reduction. Plastic intake manifolds aren't a bad thing. If a piece is made correctly, it can hold significant amounts of pressure. Link to comment Share on other sites More sharing options...
Scotty Posted May 12, 2007 Share Posted May 12, 2007 The biggest reason is cost. Cost to manufacture a plastic part is significantly less than making an aluminum part. One other advantage to molding a plastic part vs. using a cast aluminum part is you get a smooth interior surface without post processing. Rough surfaces from the casting increases the boundary layer which results in less airflow. Link to comment Share on other sites More sharing options...
Dong Homez Posted May 12, 2007 Share Posted May 12, 2007 Wouldn't there be less corrosion on a plastic part? Link to comment Share on other sites More sharing options...
NSFW Posted May 12, 2007 Share Posted May 12, 2007 One other advantage to molding a plastic part vs. using a cast aluminum part is you get a smooth interior surface without post processing. Rough surfaces from the casting increases the boundary layer which results in less airflow. How long until someone starts selling intake manifolds that are dimpled on the inside, like golfballs are on the outside? (I don't even know if the airspeeds are comparable...) Link to comment Share on other sites More sharing options...
thermobox Posted May 12, 2007 Share Posted May 12, 2007 http://www.infomine.com/investment/historicalcharts/showcharts.asp?c=Aluminum http://www.corporate.basf.com/en/sustainability/oekoeffizienz/service/presse/000419.htm?id=V00-.fC.oARrjbcp4Cy a couple of reasons. basically aluminum has tripled in price and plastics have become very good for engines efficiency. Link to comment Share on other sites More sharing options...
john_knoxville Posted May 13, 2007 Share Posted May 13, 2007 so there is no point of swapping an sti manifold into a legacy? if running stock boost, no if manipulating boost or installing a larger turbo such as on the sti, then ultimately, aluminum is stronger than plastic and is better equipped to handle the increased pressure of higher boost levels Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted May 13, 2007 Share Posted May 13, 2007 the advantage of swapping to the STI manifold is throttle body location. Throttle body location dictates which intercooler and turbo can be used. In order to use the STI intercooler and Turbo, you have to change to the STI manifold, to make the connection to the throttle body. However, some STIs with FMICs are switching to Legacy-style plastic manifolds, because they can be rotated 180 degrees, and the throttle body doesn't take the same space as the alternator, but rather comes out on the passenger's side, near the stock airbox location, where the IC piping can easily meet it. I highly doubt that a well made thermoplastic intake manifold is the weak link when upping boost pressure. You'd blow headgaskets and pistons under the resulting compression, first. Aluminum might be ultimately stronger, but at the pressures (less than 40psi) that turbos generate, plastic isn't going to fail, if designed and manufactured correctly. Plastic is used for liquid pipework at higher pressures than that. Plastic manifolds designed to suit are very likely thinner and lighter than cast aluminum to suit the same usage specifications, including pressure. Link to comment Share on other sites More sharing options...
kiyanichenko Posted May 13, 2007 Author Share Posted May 13, 2007 Oh ok, i thought it would make a power difference and torque. Since it doesn't ill just take it off and paint it red.lol Link to comment Share on other sites More sharing options...
