62beatle Posted September 17, 2012 Share Posted September 17, 2012 Hi I have legacy 1992 with tire 185/70/R14 . My question is if I can use the tire 185/75R14 without any problem. I need a comment on tire from guy who has old legacy. Link to comment Share on other sites More sharing options...
compsurge Posted September 17, 2012 Share Posted September 17, 2012 As long as all four tires are the same, it doesn't matter what size you run. Link to comment Share on other sites More sharing options...
westu37 Posted September 17, 2012 Share Posted September 17, 2012 I think he meant if there would be any drivability issues like rubbing, etc... I wouldn,t think so, my buddy has a 92 and put 205/50r16's on his. Try tires1010.com they have a tie size calculator: http://www.1010tires.com/TireSizeCalculator.asp Feel the space between your current tire and the bottom of the spring seat. If you can fit your hand between you should be fine... Wes Link to comment Share on other sites More sharing options...
mnstrmech Posted September 19, 2012 Share Posted September 19, 2012 i can answer this question easily!!!!!!!!!!!!!!!!!!!! i run 195/75/14 with NO issues at all!!! running wally world's douglas xtra-trac II... their amazing in the snow.... Link to comment Share on other sites More sharing options...
