xVern Posted May 23, 2015 Share Posted May 23, 2015 Everything I'm seeing says two pop-its, four clips, and remove. One process mentions "finagling" until the bottom clips come out. Well, i believe those bottom clips exists, but i've been finagling for a damn diddly hour. Maybe i should take off the bumper? I guess i wanted to clear my headlights anyways. Is the process the same for 05-07 as it is for 08-09? Link to comment Share on other sites More sharing options...
Varano14 Posted May 23, 2015 Share Posted May 23, 2015 I believe their are screws that need to be removed as well on the 08-09 with differs from the 05-07 i think. I have an 08 and in of the screws was so stripped I had to cut it off. Best bet it to remove bumper makes accessing the bottom screw much easier but it is possible to remove the grill with the bumper on. A mirror and a flashlight really help as well as small hands(which I don't have) Link to comment Share on other sites More sharing options...
Dispatch20 Posted May 24, 2015 Share Posted May 24, 2015 Yep, 08-09 grill is a big pain. You definitely need a flashlight and small screwdriver. There is a picture of where the screws are floating around the forum somewhere. Link to comment Share on other sites More sharing options...
xVern Posted May 25, 2015 Author Share Posted May 25, 2015 http://imgur.com/ohHQfiv.jpg Link to comment Share on other sites More sharing options...
xVern Posted May 25, 2015 Author Share Posted May 25, 2015 I forgot i had a chilton's. Link to comment Share on other sites More sharing options...
Willest_Anderson Posted June 10, 2015 Share Posted June 10, 2015 Everything I'm seeing says two pop-its, four clips, and remove. One process mentions "finagling" until the bottom clips come out. Well, i believe those bottom clips exists, but i've been finagling for a damn diddly hour. Maybe i should take off the bumper? I guess i wanted to clear my headlights anyways. Is the process the same for 05-07 as it is for 08-09? It's really easy just use brute force and you dont really need all those clips, 4 8 zip ties will do the job Link to comment Share on other sites More sharing options...
Code Posted June 10, 2015 Share Posted June 10, 2015 There is a popit in each wheel-well where the bumper and fender meet. There are popits along the bottom of the bumper. There are popits and two bolts in the top of the grille. Tremove the grille and bumper together, then separate them if neccessary. Reassemble them and reinstall grille/bumper as one piece. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
xVern Posted June 21, 2015 Author Share Posted June 21, 2015 Ended up being easier than I thought. Here are the results: Link to comment Share on other sites More sharing options...
