enzotheracer Posted December 2, 2014 Share Posted December 2, 2014 I need to know if 02-07 wrx mounting brackets will bolt up to a gen 1 2.2? (dual exhaust port). Already have the mounts and the original posts are a 1/4" too wide. Looking for some helpful insight. Link to comment Share on other sites More sharing options...
bcmaxx Posted December 2, 2014 Share Posted December 2, 2014 bump, I also need to know this! , hopefully someone knows, i'll post back if I get a definate answer! Link to comment Share on other sites More sharing options...
enzotheracer Posted December 2, 2014 Author Share Posted December 2, 2014 Please do. All my mounts are shot. Link to comment Share on other sites More sharing options...
MrTris Posted December 2, 2014 Share Posted December 2, 2014 The flat mounting plates, like these? If so, then yes. You'll have to play with the orientation to fit them properly, I had to, though, admittedly, it's easier with the engine out of the car. IIRC, I had to use those plates on my 1st gen, as well, though, that was nearly a decade ago. But I know I did successfully install GN mounts all the way around. Link to comment Share on other sites More sharing options...
enzotheracer Posted December 3, 2014 Author Share Posted December 3, 2014 Yes that is exactly what i was asking thank you! What exactly do you mean by play with the orientation? Link to comment Share on other sites More sharing options...
MrTris Posted December 3, 2014 Share Posted December 3, 2014 Yes that is exactly what i was asking thank you! What exactly do you mean by play with the orientation? I assume you don't have the motor out of the car, as I did, there, correct? What I meant was, if it's not immediately clear which way they go, you'll have to play with them a bit to be sure you're fitting them properly to the block. Link to comment Share on other sites More sharing options...
