shaneomac1602 Posted February 4, 2010 Share Posted February 4, 2010 i have spent the last hour and a half searching to no avail to my problem. i currently have: OP 2.0 cableRom Raider downloaded and installedEcu Flash downloaded and installedrom saved to my laptop i have logged my car several times, so i know my rom raider works. PROBLEM: rear o2 sensor CEL (also trying to get this to work for future Infamous1 tune) i keep trying to edit my ecu to make it "not care" about the rear o2 by disabling code (p0420). i open it with ecu flash, check the box. resave it under a different name, and then flash it to my ecu again. 20 mins of driving it comes back on. i read the ecu and the code is no longer disabled. so i decided to try it on rr ecu editor. i open ecu editor, and i try opening the saved rom from my laptop (.hex file), and it doesnt open the file. instead i get a pop up that says, "ECU Definition Not Found." i dont get it. i have all the latest definitions downloaded and loaded onto the program. im so confused why this isnt working. i want to get an (Infamous1) tune, but have to wait until i get this working properly. any help would be greatly appreciated. Thanks Guys Link to comment Share on other sites More sharing options...
m sprank Posted February 4, 2010 Share Posted February 4, 2010 Never had that exact issue. My RR editor does not save changes. I have to make changes in ECU Flash and save them. Then I can open them in RR and see the changes. Weird that my RR editor will not save changes. I have checked my user levels too. Link to comment Share on other sites More sharing options...
shaneomac1602 Posted February 4, 2010 Author Share Posted February 4, 2010 I can't figure out what I'm doing wrong. The rr editor. Won't open roms. I can change the Rom in ECU flash, and I can flash it to my ECU, but when I open it up it hasn't changed Link to comment Share on other sites More sharing options...
m sprank Posted February 4, 2010 Share Posted February 4, 2010 Lets try 1 thing at a time. The RR Editor won't open Roms. Are the latest definitons loaded? Is the file path correct? Have you tried downloading everything needed, uninstalling and reinstalling? Link to comment Share on other sites More sharing options...
shaneomac1602 Posted February 5, 2010 Author Share Posted February 5, 2010 All latest defs are downloaded. I read from ECU with ecuflash, and flash to ECU with ecuflash. Everything work except rr ECU editor. I tried reinstalling it, and the same thing happens. What all do you need for an Infamous1 tune? Do I even need ECU editor? Link to comment Share on other sites More sharing options...
m sprank Posted February 5, 2010 Share Posted February 5, 2010 Nope. As long as you can read/write with ECU Flash, log with RR Logger and pull an LV you are good. Infamous does all the writing for you. You just flash, log, LV and repeat. RR does wierd things on different machines and operating systems. It is free. Link to comment Share on other sites More sharing options...
shaneomac1602 Posted February 5, 2010 Author Share Posted February 5, 2010 i have used the logger, and ecu flash, but i havent used LV before. how do i use that? Link to comment Share on other sites More sharing options...
m sprank Posted February 5, 2010 Share Posted February 5, 2010 you just open it and press connect. need to have rr and ecu flash closed or disconnected. gives a snapshot of afr, flkc, cel's. Link to comment Share on other sites More sharing options...
shaneomac1602 Posted February 5, 2010 Author Share Posted February 5, 2010 alright, ill have to give that a try to get more familiar with it. cant wait to get a tune from shamar. Link to comment Share on other sites More sharing options...
m sprank Posted February 5, 2010 Share Posted February 5, 2010 He is good. You can keep playing with RR and see if it starts working. Your problems have motivated me to figure out my own issues with saving modified files. I am tired of making changes in ECU Flash. On my netbook (that I use for logging and tuning) the tables are sooooooo small. Link to comment Share on other sites More sharing options...
shaneomac1602 Posted February 5, 2010 Author Share Posted February 5, 2010 haha, glad i could help ya with that. Link to comment Share on other sites More sharing options...
