sleeper8406 Posted May 16, 2010 Share Posted May 16, 2010 I'll have to admit I didn't really search that long... Since I bought the car (used) the stick shift always had slop in it, up and down, left and right. I installed Perrin front shift bushings and a kartboy sts. The bushings eliminated most of the side to side slop, BUT the up and down is still there. I almost feel like its worse now. Any suggestions as to what can cause this and/ or remedy it? Thanks Link to comment Share on other sites More sharing options...
Kenpachi Posted May 16, 2010 Share Posted May 16, 2010 You might have a torn mount. If not, stiffer mounts to reduce fore/aft motion in the engine/transmission might reduce the vertical slop. Link to comment Share on other sites More sharing options...
sleeper8406 Posted May 16, 2010 Author Share Posted May 16, 2010 Where would I look to locate the mount....see if its torn on not? Link to comment Share on other sites More sharing options...
Kenpachi Posted May 17, 2010 Share Posted May 17, 2010 Vacation Pix These should help... Link to comment Share on other sites More sharing options...
sleeper8406 Posted June 1, 2010 Author Share Posted June 1, 2010 [ame=http://www.youtube.com/watch?v=kD2FGs7mvCA]YouTube- Slop[/ame] I took some video of my sloppy stick... Link to comment Share on other sites More sharing options...
modernfuse Posted June 1, 2010 Share Posted June 1, 2010 Just my opinion but this shifter design is always going to have a little play. It has linkage which is a space for movement no matter what. I installed the Rallitek shifter bushing on my stock shifter and it was a ton better than the OEM bushing, but the linkage that the bushing uses is space for movement. Like I said, just an opinion. Link to comment Share on other sites More sharing options...
darkside Posted June 1, 2010 Share Posted June 1, 2010 Get the group n trans mount that help alot Link to comment Share on other sites More sharing options...
