parad1mg Posted June 25, 2015 Share Posted June 25, 2015 Hello all, I'm researching for a single multi gauge unit that can display boost, oil pressure and fluid temperature (oil, preferably). So far the only unit I have seen that I like is the Greddy Multi D/A gauge (link:http://www.greddy.com/products/electronics/multi-da/). Anybody use or have any suggestions similar to the Greddy unit? I would like to find one that is square in profile, so i can neatly put it in the center cubby, and have the monitored parameters in lines. I currently have two gauges setup in the center cubby like most people have here in the legacies, but I really don't like how it looks. All suggestions are welcome. Link to comment Share on other sites More sharing options...
KRM Posted June 25, 2015 Share Posted June 25, 2015 btssm+android=as many gauges as you want to have. i like mine as much as most who have purchased the unit. easy to use, quick set up, and no wires to hook up Link to comment Share on other sites More sharing options...
parad1mg Posted June 25, 2015 Author Share Posted June 25, 2015 btssm+android=as many gauges as you want to have. i like mine as much as most who have purchased the unit. easy to use, quick set up, and no wires to hook up ..that can display boost, oil pressure and fluid temperature (oil, preferably). I had the torque app on my phone before i bought my AP-V3. Both however, does not display oil pressure. That is one parameter i constantly monitor an is a must for me. Does the btssm display that? Link to comment Share on other sites More sharing options...
Mike07LGT Posted June 26, 2015 Share Posted June 26, 2015 http://legacygt.com/forums/showthread.php/btssm-bluetooth-adapter-app-229709.html This thread might help 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
parad1mg Posted June 26, 2015 Author Share Posted June 26, 2015 http://legacygt.com/forums/showthread.php/btssm-bluetooth-adapter-app-229709.html This thread might help I wish the ECU offered that, but I don't believe it does. The oem oil pressure sensor appears to be an on/off switch that trips at a certain low psi value. That's correct. It is indeed just a switch. The light goes off if pressure is less than 2 psi. That's why we call it the light of death. I still cannot believe that Subaru included this to a turbo engine. Link to comment Share on other sites More sharing options...
Mike07LGT Posted June 26, 2015 Share Posted June 26, 2015 There is an oem option as well but its like $700 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
quick4dr Posted June 26, 2015 Share Posted June 26, 2015 install a oil pressure gauge off of the galley plug under the intercooler. then worry about a digital all in one for the other stuff. Oil pressure first! no pressure no reason to watch other parameters!! Link to comment Share on other sites More sharing options...
heiche Posted June 26, 2015 Share Posted June 26, 2015 FYI - if you're interested in using BtSsm to display oil pressure, you can plumb in an AEM 150psi sensor, then connect the wiring to a deleted TGV input (assuming you have one available). With a few steps in the app (I can help), you can set up a custom Oil Pressure field. It can then be used as an analog gauge, a digital gauge, or for logging. It's responsive enough that it compares to some "real" gauges If you don't have a deleted TGV input available, there will soon be an optional add-on module that with several 0-5V inputs to feed the app. /commercial BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Claw Posted June 29, 2015 Share Posted June 29, 2015 So this'll do oil pressure (with the AEM sensor) and boost? What's the difference between this solution and getting a couple of gauges? Is the BtSsm more accurate? TIA! Link to comment Share on other sites More sharing options...
MTBwrench Posted June 29, 2015 Share Posted June 29, 2015 FYI - if you're interested in using BtSsm to display oil pressure, you can plumb in an AEM 150psi sensor, then connect the wiring to a deleted TGV input (assuming you have one available). With a few steps in the app (I can help), you can set up a custom Oil Pressure field. It can then be used as an analog gauge, a digital gauge, or for logging. It's responsive enough that it compares to some "real" gauges If you don't have a deleted TGV input available, there will soon be an optional add-on module that with several 0-5V inputs to feed the app. /commercial I just became very intrigued. MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
heiche Posted June 29, 2015 Share Posted June 29, 2015 So this'll do oil pressure (with the AEM sensor) and boost? What's the difference between this solution and getting a couple of gauges? Is the BtSsm more accurate? TIA! Not necessarily more accurate. There are a few folks that just like to see what's going on in their ECU, and that includes some of the sensors. Logging can be helpful too. Some even mount a tablet. Then, even though oil pressure isn't one of the existing sensors, it can be added as described BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Strizzy Posted July 1, 2015 Share Posted July 1, 2015 I liked my PLX setup, but now just using it for my WBO2. I'm using the vent gauge for my boost and oil/fuel pressure. http://www.plxdevices.com/category-s/109.htm My bad luck build Link to comment Share on other sites More sharing options...
Streetlegal Posted July 1, 2015 Share Posted July 1, 2015 You can get a set of aeroforce interceptor gauges. I have a pair for my trans am. They read everything your ECU sees and anything else you hook up to them. Link to comment Share on other sites More sharing options...
parad1mg Posted July 2, 2015 Author Share Posted July 2, 2015 Not necessarily more accurate. There are a few folks that just like to see what's going on in their ECU, and that includes some of the sensors. Logging can be helpful too. Some even mount a tablet. Then, even though oil pressure isn't one of the existing sensors, it can be added as described I have a V3 to show me whatever the ECU sees. That's why I am not considering any "gauge" that plugs into the OBD port. I liked my PLX setup, but now just using it for my WBO2. I'm using the vent gauge for my boost and oil/fuel pressure. http://www.plxdevices.com/category-s/109.htm I am leaning towards this. If i can have one gauge that has specific sensors, then I'm set Link to comment Share on other sites More sharing options...
parad1mg Posted July 2, 2015 Author Share Posted July 2, 2015 You can get a set of aeroforce interceptor gauges. I have a pair for my trans am. They read everything your ECU sees and anything else you hook up to them. those look nice.. checking them out right now. Link to comment Share on other sites More sharing options...
