Go Back   Subaru Legacy Forums > Technical Forums > Tuning
Reload this Page need help reading logs...
#1: 11-04-2009, 06:13 PM
 ole whore
ole whore's Avatar
Car: 2004 black lgt (2005 us)
Send a private message to ole whore Find all posts by ole whore Reply With Quote
hey i did some logs and i need to understand them
ole whore
Find More Posts by ole whore
#2: 11-04-2009, 07:35 PM
 Sebastian
Sebastian's Avatar
Car: 05 Legacy GT
Send a private message to Sebastian Find all posts by Sebastian Reply With Quote
Complete noob in tuning but I will chime in here.
From what others who have helped me have told me, you need to change what parameters you are logging. You need to log Time, Engine Load (4 byte), Engine Speed, Feedback Knock Correction (4 byte), Fine Learning Knock Correction (4 byte), Ignition Total Timing, Knock Sum, Manifold Relative Pressure, Primary Wastegate Duty Cycle, Throttle Opening Angle, Turbo Dynamics Integral (2 byte), and Vehicle Speed.
Also, no need to log it, but make sure that your IAM is at 1.00. You usually need to run the car for a few minutes after a reflash to get it back up to 1.00. It's also helpful to post a learning view up with your datalogs.
In order for people to better help you, do a couple of logs using the parameters I listed. Also the best way to do a log is to start the log at about 2500 rpms in 3rd gear and run WOT to about 6300 rpms. Also post your mods to the car.
Sebastian
Find More Posts by Sebastian
#3: 11-04-2009, 11:22 PM
 LittleBlueGT
LittleBlueGT's Avatar
Title: RS4 killer
Car: 05 Atlantic Blue non-limited GT MT
Send a private message to LittleBlueGT Find all posts by LittleBlueGT Reply With Quote
I hate to say this, but those are about the worse logs Ihave seen to date.
IAM is down to almost nothing. The thing that strikes me right off the bate is the AFR reading, 14.xx:1 on WOT. Something is wrong, big time.
DO NOT GET INTO BOOST UNTI IT IS FIXED, AT ALL!!!!!!!
Is the vacuum hose going from the intake manifold to the FPR hooked up?
*** FS - AVO380, pm me
LittleBlueGT
Find More Posts by LittleBlueGT
#4: 11-04-2009, 11:41 PM
 NSFW
NSFW's Avatar
Title: Stage Free
Car: 5mtblackturbowagon
Send a private message to NSFW Find all posts by NSFW Reply With Quote
That's true. I wrote about that here:
http://www.romraider.com/forum/topic5384.html
I have only looked at the first log. In spite of having the wrong set of parameters, it's clear that this car is not healthy. I completely agree with LBGT - stay out of boost until you find out what the problem is and get it fixed.
IAM starts at 0.5 (bad) and drops to 0.1875 (worse). Dropping IAM causes the engine to pull timing across the board. It does that only when the ECU believes you're getting a lot of knock.
Knock sum starts at 13 (means nothing) and rises to 32 (yikes). That signifies either a lot of knock, or a rattle somewhere that the ECU believes is knock.
Ole Whore, do you have any theories on what's going on?
NSFW
Find More Posts by NSFW
#5: 11-05-2009, 12:29 AM
 LittleBlueGT
Title: RS4 killer
I am surprised you do not mention the AFR.
LittleBlueGT
#6: 11-05-2009, 12:34 AM
 LittleBlueGT
Title: RS4 killer
I take that back. He is obviously logging with RR, but the AFR is eerily stable and hardly changing at all. Maybe front O2 is shot?
Either way, we need to know mods.
Post up a LV, even though I am scared to see it. Then we can see learned LTFTs.
Now that I look again I see crazy low MAFg/s values. Like maxxing out at 134 g/s? Something major is screwy here.
LittleBlueGT
#7: 11-05-2009, 12:38 AM
 NSFW
NSFW's Avatar
Title: Stage Free
AFR looked reasonable in the 1st log, and it's the only one I looked at.
That one log was enough. /
NSFW
#8: 11-05-2009, 12:41 AM
 NSFW
NSFW's Avatar
Title: Stage Free
In the first log, MAF never gets high, but throttle is mostly 50% or less.
AFR is mostly 11.14 in that log, which is just the lower limit.
I'd really like to know the car's history too.
NSFW
#9: 11-05-2009, 05:42 AM
 LittleBlueGT
Title: RS4 killer
That log almost looks OK AFR wise, but in reality the OEM sensor should be maxxed out low much sooner.
Look at AFR in log#2.
LittleBlueGT
#10: 11-05-2009, 09:12 AM
 ole whore
ole whore's Avatar
hey guys thanks for all your HONEST inputs, i actually felt like i am being scold....
first, this is not my car and the vehicle is a legacy spec b auto
the car has no mods and the owner took the car by A FRIEND to tune.......
resulting in what you see
two logs were 3rd gear pulls from about 2000 rpm to about redline,
and with regards to the log parameters, i read these are the parameters you need from an existing thread
ole whore
#11: 11-05-2009, 09:40 AM
 iNVAR
iNVAR's Avatar
Car: 05 LGT Ltd 5MT Infamoused Stg2
Send a private message to iNVAR Find all posts by iNVAR Reply With Quote
wow that car is one sick puppy....
iNVAR
Find More Posts by iNVAR
#12: 11-05-2009, 11:36 AM
 NSFW
NSFW's Avatar
Title: Stage Free
Have you showed this thread to the owner of the car? Or the tuner? I am curious as to whether the tuner actually caused all the knock, or whether he did some baseline pulls, saw all the knock, and then told the owner to go get his car fixed.
Where's the thread that suggested those parameters? I'd like to get it fixed. Thanks!
NSFW
#13: 11-05-2009, 02:01 PM
 ole whore
ole whore's Avatar
you guys are so harse, out of the 12 parameters , i had 10......come on be kind to the NOOB
ole whore
#14: 11-05-2009, 02:02 PM
 ole whore
ole whore's Avatar
anyways thanks for all your responces , we decided to go to the local ecutek rep to get it tuned.................
ole whore
#15: 11-05-2009, 02:28 PM
 LittleBlueGT
Title: RS4 killer
Tell us your mods?
LittleBlueGT
Similar Threads
Noob Tuning - OpenSource Stg 1 - With Logs dease42 Tuning 9 08-05-2009 07:01 PM
Cobb OTS Stage 1 Logs and Impression JaeGT Tuning 2 07-07-2009 05:32 PM
First Stage I Logs, Questions, and Impressions z28dreams Tuning 7 11-05-2008 12:42 PM
CEL 2096 & Logs - help interpretting pls SlightlyEvil Tuning 8 05-30-2008 11:44 AM
Logs, Logs I have Logs..... TPLGT Tuning 10 05-07-2008 05:26 PM
