#1:
11-04-2009, 05:13 PM
need help reading logs...
Car: 2004 black lgt (2005 us)
hey i did some logs and i need to understand them
#2:
11-04-2009, 06:35 PM
Car: 05 Legacy GT
Complete noob in tuning but I will chime in here.
From what others who have helped me have told me, you need to change what parameters you are logging. You need to log Time, Engine Load (4 byte), Engine Speed, Feedback Knock Correction (4 byte), Fine Learning Knock Correction (4 byte), Ignition Total Timing, Knock Sum, Manifold Relative Pressure, Primary Wastegate Duty Cycle, Throttle Opening Angle, Turbo Dynamics Integral (2 byte), and Vehicle Speed.
Also, no need to log it, but make sure that your IAM is at 1.00. You usually need to run the car for a few minutes after a reflash to get it back up to 1.00. It's also helpful to post a learning view up with your datalogs.
In order for people to better help you, do a couple of logs using the parameters I listed. Also the best way to do a log is to start the log at about 2500 rpms in 3rd gear and run WOT to about 6300 rpms. Also post your mods to the car.
#3:
11-04-2009, 10:22 PM
Title: RS4 killer
Car: 05 Atlantic Blue non-limited GT MT
I hate to say this, but those are about the worse logs Ihave seen to date.
IAM is down to almost nothing. The thing that strikes me right off the bate is the AFR reading, 14.xx:1 on WOT. Something is wrong, big time.
DO NOT GET INTO BOOST UNTI IT IS FIXED, AT ALL!!!!!!!
Is the vacuum hose going from the intake manifold to the FPR hooked up?
#4:
11-04-2009, 10:41 PM
Title: Obsolete
Car: 5mtblackturbowagon
That's true. I wrote about that here:
http://www.romraider.com/forum/topic5384.html
I have only looked at the first log. In spite of having the wrong set of parameters, it's clear that this car is not healthy. I completely agree with LBGT - stay out of boost until you find out what the problem is and get it fixed.
IAM starts at 0.5 (bad) and drops to 0.1875 (worse). Dropping IAM causes the engine to pull timing across the board. It does that only when the ECU believes you're getting a lot of knock.
Knock sum starts at 13 (means nothing) and rises to 32 (yikes). That signifies either a lot of knock, or a rattle somewhere that the ECU believes is knock.
Ole Whore, do you have any theories on what's going on?
#5:
11-04-2009, 11:29 PM
Title: RS4 killer
I am surprised you do not mention the AFR.
#6:
11-04-2009, 11:34 PM
Title: RS4 killer
I take that back. He is obviously logging with RR, but the AFR is eerily stable and hardly changing at all. Maybe front O2 is shot?
Either way, we need to know mods.
Post up a LV, even though I am scared to see it. Then we can see learned LTFTs.
Now that I look again I see crazy low MAFg/s values. Like maxxing out at 134 g/s? Something major is screwy here.
#7:
11-04-2009, 11:38 PM
Title: Obsolete
AFR looked reasonable in the 1st log, and it's the only one I looked at.
That one log was enough.  /
#8:
11-04-2009, 11:41 PM
Title: Obsolete
In the first log, MAF never gets high, but throttle is mostly 50% or less.
AFR is mostly 11.14 in that log, which is just the lower limit.
I'd really like to know the car's history too.
#9:
11-05-2009, 04:42 AM
Title: RS4 killer
That log almost looks OK AFR wise, but in reality the OEM sensor should be maxxed out low much sooner.
Look at AFR in log#2.
#10:
11-05-2009, 08:12 AM
hey guys thanks for all your HONEST inputs, i actually felt like i am being scold....
first, this is not my car and the vehicle is a legacy spec b auto
the car has no mods and the owner took the car by A FRIEND to tune.......
resulting in what you see
two logs were 3rd gear pulls from about 2000 rpm to about redline,
and with regards to the log parameters, i read these are the parameters you need from an existing thread
#11:
11-05-2009, 08:40 AM
Car: 05 LGT Ltd 5MT Infamoused Stg2
wow that car is one sick puppy....
#12:
11-05-2009, 10:36 AM
Title: Obsolete
Have you showed this thread to the owner of the car? Or the tuner? I am curious as to whether the tuner actually caused all the knock, or whether he did some baseline pulls, saw all the knock, and then told the owner to go get his car fixed.
Where's the thread that suggested those parameters? I'd like to get it fixed. Thanks!
#13:
11-05-2009, 01:01 PM
you guys are so harse, out of the 12 parameters , i had 10......come on be kind to the NOOB
#14:
11-05-2009, 01:02 PM
anyways thanks for all your responces , we decided to go to the local ecutek rep to get it tuned.................
#15:
11-05-2009, 01:28 PM
Title: RS4 killer
Tell us your mods?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
