Haha, I don't care about the credit, I'm just glad I could be of help to the community .
Oh btw how's the dp->exhaust holding up. I don't feel like buying an adapter yet as I am looking forward to purchasing a XO2 setup from ebay. I just want to throw this bad boy on and step away from the shitty Subaru stock tune with studders.
No leaks that I hear or see in my logs. I will get under the car tomorrow and look/feel. Funny, the extra 3" gasket I had was from a X02 exhaust. I would imagine that 1 gasket and some exhaust gasket in a tube would do the trick for now. Its not that the flanges aren't lining up. They are very flat. Its the 3" hole up against the 2.5"" hole and the extra back pressure its causing.
I have an Xo2 exhaust. Its on my LGT with the Cobb DP. Please don't ask me to swap exhausts now. Since I have both, and previously had the Cobb and SPT set up on the LGT, I an say that I would DEFINITELY go for the X02 CBE with the ERZ DP. I even got my CBE from CX on eBay. It might just be the best bang for the buck stage 2 set up you can buy.
All right. I have a tune that I am willing to share. I still need to drive around (aggressively) logging and make sure that all parameters are good. But, I logged the previous rev for 200+ miles and was happy so I am fairly confident this will be good (the only changes since that rev have been to WOT). If I make any changes to the ROM I will share the updated file. This rev has been logged and logs are attached, just not for an extended drive yet. Logs are 3rd gear pull.
The tune is for an 08 USDM SpecB stage 2 using CAN91 fuel. Stock intake and filter. Only motor mods on my car are the ERZ DP and the SPT CBE.
AFR is very conservative. Peak boost is approx. 18psi.
2 logs and Dyno plot are also attached. LV's taken after each log.
Because this site won't allow the posting of .hex files (don't support the format) I can not post the tune here. But if you shoot me a PM I will email you the file. I don't want to just post up tables and make people cut and paste them into the ROM.
DISCLAIMER:
USE OF THIS TUNE IS AT YOUR OWN RISK. I ASSUME NO RESPONSIBILITY OR MAKE ANY CLAIMS OF MERCHANTABILITY OR FITNESS FOR YOUR APPLICATION.
Edit: Sorry for the poor size of the screen shot, it was taken from my 8" netbook. The peak HP is 262 @ 6220RPM and the peak TQ is 294 @ 3710RPM.
Reason: Poor photo quality
I wouldn't ask you to do that.
Best bang for the buck brand NEW stage 2 setup for sure.
I was the last to get in on the deal for $260. Fitment was dead on, quality was better than it should have been for what I paid. Would definitely recommend, even for the $340 it goes for now.
