Vaders_3.0R Posted January 19, 2016 Share Posted January 19, 2016 Hey all, I'm gauging interest in some custom fender flares for the 4th gen platform. Keep in mind this is just to collect interest. The flares will look something similar to these: http://www.racingsolution.com/subaru/wrx-02-07/exterior/subaru-wrx-rs-fender-flares-02-03.html I am in contact with the owner who would need a donor car (likely mine) and would need at least 10 people who are on board to start making a mold. The flares will likely be similar width and would continue around the entire edge of the wheel. Drop your name down below if you're interested. Link to comment Share on other sites More sharing options...
boxkita Posted January 20, 2016 Share Posted January 20, 2016 Calling Sgt.Gator ! Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Sgt.Gator Posted January 20, 2016 Share Posted January 20, 2016 For $500 I'd be all in!!!!! Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
shralp Posted January 20, 2016 Share Posted January 20, 2016 I'd probably bite for $500 if fit and finish is legit Link to comment Share on other sites More sharing options...
I3eXa Posted January 20, 2016 Share Posted January 20, 2016 interested in seeing how they look but more interested in gofast parts currently Link to comment Share on other sites More sharing options...
boxkita Posted January 20, 2016 Share Posted January 20, 2016 interested in seeing how they look but more interested in gofast parts currently Gofast parts go faster on wider tires enabled by flares... Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
I3eXa Posted January 20, 2016 Share Posted January 20, 2016 Gofast parts go faster on wider tires enabled by flares... hmm...I see what you're saying but no Link to comment Share on other sites More sharing options...
magnusonsubie Posted January 20, 2016 Share Posted January 20, 2016 Gofast parts go faster on wider tires enabled by flares... These aren't my style of how a flare on our wagons should work. Give me a couple years and I'll have a wide body wagon done that also will go on the track to at least see how fast and how much grip it has. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
boxkita Posted January 20, 2016 Share Posted January 20, 2016 These aren't my style of how a flare on our wagons should work. Give me a couple years and I'll have a wide body wagon done that also will go on the track to at least see how fast and how much grip it has. On 235/40/17 BFG R1's, I've hit 1.5G. You might want to work with Sgt.Gator to come up with a solution. Between aero & a cage for rigidity, he's got a headstart on finding a higher number. Cause we've already seen crazy8 & the manta ray: http://forums.nasioc.com/forums/showthread.php?t=2434493 & http://legacygt.com/forums/showpost.php?p=4264580&postcount=256 http://minkara.carview.co.jp/en/userid/159507/blog/d20120922/ Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
quick4dr Posted January 20, 2016 Share Posted January 20, 2016 my flares were no 500 Link to comment Share on other sites More sharing options...
Sgt.Gator Posted January 20, 2016 Share Posted January 20, 2016 Of course the flares would have to truly make room for wider tires/wheels. Then I'd have to buy new sets of dry and wet competition wheels- tires in 255 or 275. Yikes! $$$$$ Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
battelready Posted January 20, 2016 Share Posted January 20, 2016 On 235/40/17 BFG R1's, I've hit 1.5G. You might want to work with Sgt.Gator to come up with a solution. Between aero & a cage for rigidity, he's got a headstart on finding a higher number. Cause we've already seen crazy8 & the manta ray: http://forums.nasioc.com/forums/showthread.php?t=2434493 & http://legacygt.com/forums/showpost.php?p=4264580&postcount=256 http://minkara.carview.co.jp/en/userid/159507/blog/d20120922/ Id be in for something that looks like minkara one. I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
boxkita Posted January 20, 2016 Share Posted January 20, 2016 Of course the flares would have to truly make room for wider tires/wheels. Then I'd have to buy new sets of dry and wet competition wheels- tires in 255 or 275. Yikes! $$$$$ 275 needs about 2 inches in rear. About an inch in front. You should think bigger like 295 or 335 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
magnusonsubie Posted January 20, 2016 Share Posted January 20, 2016 275 needs about 2 inches in rear. About an inch in front. You should think bigger like 295 or 335 That's where I was thinking. Over 300 on an 18" wheel. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Vaders_3.0R Posted January 20, 2016 Author Share Posted January 20, 2016 I think that we have the opportunity to get flares made that everyone agrees to and wants. http://legacygt.com/forums/showpost.php?p=4264580&postcount=256 These are a nice solution but if I am going to put time and $$ into making my car allow for wider wheels and tires I want it to have a more OEM look. Simply my opinion and take what you will from it. http://minkara.carview.co.jp/en/user...log/d20120922/ I love the looks of this but that seems a little out of the ballpark as most of you realize. Something along the lines of these to me seems a little more achievable. I think with a little more aggressive look flares like this would both compliment the car's body lines as well as add functional width for adding a wider stance. http://www.topmix.com.hk/img/product/Subaru%2006%20Legacy%20CN%20Style%20Wide%20Body%20Kit_3_L.jpg http://www.topmix.com.hk/img/product/Subaru%2006%20Legacy%20CN%20Style%20Wide%20Body%20Kit_2_L.jpg Keep the opinions coming. Whoever wants to photoshop some ideas together would be great too! Link to comment Share on other sites More sharing options...
magnusonsubie Posted January 21, 2016 Share Posted January 21, 2016 Those that you posted on the white car appear very Audi-esk to me. I personally want something like this. But I also know these are going to be very difficult and are not a "Bolt on and cut" application. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
wesleyCrowbar Posted January 21, 2016 Share Posted January 21, 2016 Uunnfff Link to comment Share on other sites More sharing options...
I3eXa Posted January 21, 2016 Share Posted January 21, 2016 Those that you posted on the white car appear very Audi-esk to me. I personally want something like this. But I also know these are going to be very difficult and are not a "Bolt on and cut" application. Those are flared fenders not fender flares lol. Looks interesting though Sent from somewhere in Potatoland Link to comment Share on other sites More sharing options...
magnusonsubie Posted January 21, 2016 Share Posted January 21, 2016 Those are flared fenders not fender flares lol. Looks interesting though Sent from somewhere in Potatoland meh same difference to me. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
boxkita Posted January 21, 2016 Share Posted January 21, 2016 looks like wrx fenders were photoshopped onto a lgt Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
magnusonsubie Posted January 21, 2016 Share Posted January 21, 2016 looks like wrx fenders were photoshopped onto a lgt If it truly is a photoshop and not a real car I will be impressed. I have a few more pictures of it somewhere but differing angles and the flares look the same everywhere. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
boxkita Posted January 21, 2016 Share Posted January 21, 2016 yeah, said that wrong. Meant it looked like wrx fender flares were put on lgt. There's video of the car somewhere. It's the rear set that look funny to me Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted January 24, 2016 Share Posted January 24, 2016 Wandering thru rallysportdirect's site and found these: https://www.rallysportdirect.com/part/accessories/lic-gdprff01-lic-motorsports-rear-fender-flares-carbon total weight 1lb :-) Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Hannya Posted January 24, 2016 Share Posted January 24, 2016 Would like to see final rough draft of the flares first before I give the money out. But count me in. I want to finish the show stuff on the car by summer. Bags are about to start soon. Link to comment Share on other sites More sharing options...
Rhitter Posted January 25, 2016 Share Posted January 25, 2016 Wondering thru rallysportdirect's site and found these: https://www.rallysportdirect.com/part/accessories/lic-gdprff01-lic-motorsports-rear-fender-flares-carbon total weight 1lb :-) LIC makes good stuff. These look awesome My OBXT build Link to comment Share on other sites More sharing options...
