motorbykemike Posted March 6, 2014 Share Posted March 6, 2014 i know it's a bit of a squeeze onto that rim but anybody know if they wil fit on an 05 lgt w/ stock wheels and not rub the strut car is on bilstien hd's that have a higher spring perch , not worried about that , just the strut bodies / inside clearances tire is a Dunlop wrx takeoff have the same tires on 7.5 wide 04 bbs and the squeeze will not be bad Link to comment Share on other sites More sharing options...
idiot4hire Posted March 6, 2014 Share Posted March 6, 2014 I am no expert but I think that to wide for the wheel you will have bulging side walls Link to comment Share on other sites More sharing options...
motorbykemike Posted March 6, 2014 Author Share Posted March 6, 2014 looking at these on a 7.5 , I don't think so worried about the clearance inside Link to comment Share on other sites More sharing options...
Drift Motion Posted March 6, 2014 Share Posted March 6, 2014 stock LGT wheels are not 7.5, but 7 inch wide Link to comment Share on other sites More sharing options...
motorbykemike Posted March 7, 2014 Author Share Posted March 7, 2014 stock LGT wheels are not 7.5, but 7 inch wide yeah , I got that part , these are 04 sti bbs that I am looking at the tires mounted on , with these rims the inside of the rim is 4.4mm closer to the strut .....these are the rims I have the tires mounted on now and see how they fit , on the rims , I think the tires will be fine on a 7" rim as far as the "bubble" I am asking if they fit on a stock oem lgt rim , 7" 55et , on an lgt w/ bils and not have clearance issues inside , I am naturally assuming the outboard clearance should be more than adequate . I wanna know if anybody has fit this size tire on a stock wheel and what brand/model and if they had issues with inboard clearances this forum is full of knowledge/experience , I just have to wait for the .............. results on their specific rig p.s. my rig is less than 2* camber Link to comment Share on other sites More sharing options...
Drift Motion Posted March 7, 2014 Share Posted March 7, 2014 let's just say 2011+ WRX wheels fit on stock LGTs those are 17x8 with +53mm your 7.5 inch wide wheels with the same tire will be just fine Link to comment Share on other sites More sharing options...
ttnio Posted March 7, 2014 Share Posted March 7, 2014 End of discussion. Link to comment Share on other sites More sharing options...
motorbykemike Posted March 7, 2014 Author Share Posted March 7, 2014 ok people , it breaks down like this I have 2 sets of the same wrx takeoff 235/45/17 dunlops one set is mounted on the 04 bbs and are on my fozzy here's where it get really tricky ..... will the other set fit on a stock lgt wheel on the lgt ? Link to comment Share on other sites More sharing options...
Drift Motion Posted March 7, 2014 Share Posted March 7, 2014 what's so hard to comprehend? if you have everything already, just go try them on if you want to be lazy, then listen to what others has said 235 on a 7 inc wide wheel looks stupid 45 is too tall Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 7, 2014 Moderators Share Posted March 7, 2014 what's so hard to comprehend? if you have everything already, just go try them on if you want to be lazy, then listen to what others has said 235 on a 7 inc wide wheel looks stupid 45 is too tall 45 is not "too tall". BUT, when you combine 45 with a 235 tire on a 7" wheel, the bulge / roll over tendency is going to be terrible. Talk about soft sidewalls... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
scontivt Posted March 7, 2014 Share Posted March 7, 2014 I'm running this tire size for my winter tires. Not the best winter traction because of the width, but I find the ride a little more soft over all the salt and plow induced pot holes. I can confirm they fit. I picked up my set for $120 at a tire swap. Couldn't beat the price anywhere at that time... lol. Just to let you know, they are a B*tch to install on the Stock LGT wheels. If you are going to attempt it with a friends tire machine (like I did) be prepared for a little cussing... If you bring it some place, they may or may not refuse to mount them. Link to comment Share on other sites More sharing options...
motorbykemike Posted March 7, 2014 Author Share Posted March 7, 2014 scontivt , thanx for the info may I ask exactly what tire you are running ? Link to comment Share on other sites More sharing options...
scontivt Posted March 7, 2014 Share Posted March 7, 2014 Dunlop Graspic. Love the tire. I will be buying a new set of the proper size for next year. Link to comment Share on other sites More sharing options...
frank_ster Posted March 28, 2014 Share Posted March 28, 2014 i have 235 /45 17's on my stock rims and it looks perfect. the only pic i can find. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
motorbykemike Posted March 29, 2014 Author Share Posted March 29, 2014 thanx frankster and esp thnx for the pic I ended up w/ the 04 sti/bbs on her car w/ the 235's , but she is not digging the gold , anyways ............. car has avo offset/caster bushings up front and is about 3/4" lower as well , tire is about 1/4" from the fender liner while turning no rubbing anywhere but is very , very close to errthang front and back think I will try the other set of 235's on the stockers as well l Link to comment Share on other sites More sharing options...
motorbykemike Posted March 29, 2014 Author Share Posted March 29, 2014 I do think this is the perfect size tire for this car Link to comment Share on other sites More sharing options...
