#15: 08-08-2013, 10:50 AM
 Max Capacity
Max Capacity's Avatar
Car: 05GT Wagon 5MT stg2, 09 specB stg2
As for a clutch, the Spec 2+ I had seemed to be easy to launch the car with. You can pre-load it while holding the e-brake and let the clutch slip a bit while at launch rpm. That loads the drivetrain so the shock is less when you launch.
Hold off on a CAI until you decide turbo and FMIC or TMIC.
252,000miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. CHECK your oil, these cars use it.
Engine Build - Click Here
