Subaru Legacy Forums
-   Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) (http://legacygt.com/forums/forumdisplay.php?f=12)
-   -   JDM ECU wiring diagram (http://legacygt.com/forums/showthread.php?t=9638)
SC GT 03-10-2005 04:19 AM
http://tara555.hp.infoseek.co.jp/ECU%20diagram.html
Translated:
1. RY: Clutch switch 2. WB: Front O2 (A/F) sensor heater signal 2 3. WB: Front O2 (A/F) sensor heater signal 1 4.? 5. ? 6. R: Ground (front O2 (A/F) sensor heater 2) 7. R: Ground (front O2 (A/F) sensor heater 1) 8.? 9. ? 10 ? 11. ? 12. ? 13 ? 14. RG: Purge control solenoid valve 15.? 16 ? 17. OrW: Engine warning light 18 V: Intake AVCS solenoid (RH) signal (+) 19. LB: Intake AVCS ソレノイ h (LH) signal (+) 20. L: Exhaust AVCS solenoid (RH) signal (+) 21 R: Exhaust AVCS solenoid (LH) signal (+) 22. BR: Alternator - 23. P: Engine rpm output 24.? 25. SB: Front O2 (A/F) sensor seal 26. W: Front O2 (A/F) sensor signal (? ) 27.? 28. Sb: Intake AVCS solenoid (RH) signal (? ) 29. P: Intake AVCS solenoid (LH) signal (? ) 30. LOr: Exhaust AVCS solenoid (RH) signal (? ) 31. RW: Exhaust AVCS solenoid (LH) signal (? ) 32. BY: Supercharging pressure control solenoid valve 33. B: Front O2 (A/F) sensor signal (+) 34. BL: ? 1. BW: Ground (power source supply) 2. RW: Rear O2 sensor heater signal 3.? 4. BW: Ground (power source supply) 5. YL: Control unit power source supply 6. YL: Control unit power source supply 7.? 8. GW: Intake camshaft position sensor (LH) 9. GR: Intake camshaft position sensor (RH) 10 W: Crankshaft position sensor signal (+) 11.? 12. B: Ground (ignition system) 13? 14. ? 15. WL: Ignition control No.416. GW: Ignition control No.317. YG: Ignition control No.218. RY: Ignition control No.119. W: Backup power source supply 20. R: Exhaust camshaft position sensor (LH) signal (+) 21 B: Exhaust camshaft position sensor (RH) signal (+) 22. B: Crankshaft position sensor signal (? ) 23.? 24. BR: Radiator fan relay 2 control 25. RL: Radiator fan relay 1 control 26. ? 27. Lg: Fuel pump control unit signal 228. G: Exhaust camshaft position sensor (LH) signal (? ) 29. W: Exhaust camshaft position sensor (RH) signal (? ) 30. SB: Exhaust camshaft position sensor seal 31, SB: Crankshaft position sensor seal 32. BL: Starter relay 33. LOr: A/C relay control 34.? 35. RL: Electronic control throttle motor relay B136 B137 1. ? 2. ? 3. PG: Fuel injector No.4 4. PB: Fuel injector No.3 5. PL: Fuel injector No.2 6. P: Fuel injector No.1 7. W: Cruise control main switch 8. BrR: Brake switch 2 9. Y: Brake switch 110.? 11. YL: Cruise control command switch 12.? 13 YL: Intake air temperature sensor signal 14. BrW: Engine coolant temperature sensor signal 15. GB: Accelerator position sensor power source supply 16 LY: Sensor power source supply 17. Y: Accelerator position sensor main 18 W: Electronic control throttle main 19. BL: ? 20. ? 21? 22. YW: Manifold pressure sensor signal 23. LR: Air flow sensor signal 24.? 25. L: Knock sensor signal 26.? 27. ? 28. R: Accelerator position sensor sub 29. Or: Electronic control throttle sub 30. YB: Air conditioner pressure switch 31. BG: Air flow sensor ground 32. SB: Air flow sensor seal 33. SB: Knock sensor seal 34. L: Accelerator position sensor ground 35. YG: Ground (sensor) 1. BL: Ground (control system) 2. BL: Accelerator position sensor seal 3. LR: Ground 4. WB: Electronic control throttle motor (? ) 5. GY: Electronic control throttle motor (+) 6. LR: Electronic control throttle power source 7. BP: Ground (injector) 8. LW: Starter switch 9. GL: Neutral position switch 10 PB: Power-steering oil pressure indicator lamp switch 11.? 12. ? 13 VY: Blower - fan switch 14. GR: Ignition switch 15. P: Static test mode connector 16 Lg: Main relay 17. P: A/C switch 18 R: CAN communication 19. WL: イモビライザーシステム 20. VR: SSR communication line 21? 22. ? 23. ? 24. PG: Clear memory switch 25. W: Rear O2 sensor signal 26. L: CAN communication 27. BR: イモビライザーシステム 28. LgR: Fuel pump control unit signal 129. V: Selection monitor connector 30.? 31. SB: Rear O2 sensor seal
SpankyLGT 03-10-2005 08:05 AM
http://babelfish.altavista.com is your friend. Does an excellent translation of the page for you.
Jaxx 03-10-2005 10:20 AM
um for what car/engine
Rage123 05-14-2006 12:53 PM
I am trying to install a Apexi turbo timer and when i followed this diagram that you have had to have windows translate it. But when i hooked the white wire the front oxygen sensor to b134 33 the 02 sensor did not work I checked the pin placement on how they are all lined up they all matched but i sooned realized that the jdm model is a different ecu same setup and everything. But I have the a different model number then this one. And if anyone has a ignition diagram that would be helpful too thanks
sgt 05-14-2006 03:05 PM
I think the turbo timer O2 readout is meant for narrow band sensors only
MDTURBO 05-14-2006 03:10 PM
^^ Correct... narrow band 0-1v, ours is 1-3v
Rage123 05-15-2006 06:28 PM
thanks alot for that info very helpful. just need a ignition diagram and thats about it. My buddy and I hooked it up the other night and when I started it it was fine but when i pushed in the clutch it made a grinding noise which is obviously not good for my car lol but did not do any damage thank God so pretty much we just ungrounded the wire so it would stay off. thanks guys
