Koni struts for LGT. GREAT struts, GREAT price!
I'm a HUGE fan of the Koni inserts. They're definitely one of the very best aftermarket struts in any price range. The dampening curves are great, the adjustment is extremely effective, the performance rocks, and Koni is flat-out amazing about their lifetime warranty.
I know some people shy away because they're inserts and not complete replacement struts. The reasons I actually really like the insert idea are: *** fitment of brake lines, abs/speed sensor lines, hub bolts, and spring perches is PERFECT because all of those things are OEM. Getting the brake lines and sensor lines to attach properly (i.e. no zip ties necessary!) is a big issue on a lot of aftermarket struts. Since Koni is using the OEM strut housings you're guaranteed absolutely perfect fitment. *** Koni isn't spending money measuring for and manufacturing strut housings for every car model out there (which would be the part where the strut bolts to your hub, the housing itself, the spring perch, the brake line brackets, etc). You're not paying for a strut housing. I think your money is really going into the internals of the insert -- the valving mechanisms, dampening adjustment, etc. I think it shows in the extreme quality & performance of the product for the price. *** The installation is WAY easier than most people expect. This is usually a big reason people shy away from inserts but it's shockingly straight forward. If you're actually doing the suspension install yourself, I'm very confident that doing the installation of the inserts portion of it will be the simplest part of the whole deal. Most professional shops are familiar with doing inserts and charge a minimal amount for the process, as it really does not take long. So............ Koni Sport Inserts for the 05+ Legacy models!!! 8610 1447 Fronts 8010 1053 Rears Our normal price is $595 shipped for the set of four! :eek: If you see it less somewhere else, send us a link... but this price should be pretty freaking good!!! MSRP is $900... EDIT: PRICE CHANGE! Koni raised their prices across the board by 10% as of September 1, 2008. Current price from us on the LGT Koni set is $665 shipped in the U.S.! Jeremy |
I thought only the rears were inserts?
Jeremy |
Thats a good price, I love mine.
Thanks for the bumps, guys!
A lot of people still don't know that we carry (and STOCK) so many brands. 95% of the time we have no problem whatsoever beating any advertised price by a nice margin! www.crucialracing.com/products/other_brands/index.php Jeremy |
Are the Koni fronts designed for the usdm LGT tophats or the jdm?
Special price w/Crucial Springs?
Hey Jeremy,
Any plans of offering a "special" package discount if these are purchased along with your soon to be released springs? |
Jeremy |
If it requires the Spec B tophats, it could cost a buyer a lot of money if he is paying for install, it doesn't work, then has to spring for the Spec B top hats and the cost of another install. EDIT: I'm not being critical of Crucial because I don't know how they are going to handle this, but I hate it when vendors place the burden of discovering whether a certain part fits upon the buyer instead of doing the leg work themselves before promoting a product. I've bought stuff from Crucial before, and I'm sure they'll find out the answer. |
Here, this should answer it. From Koni's site:
Jeremy |
Well.... you can be confident that I'll at least try ;)
I'm riding on Konis and I absolutely love them! if I knew Jeremy was selling them I would have bought them from him instead. These shocks will work well with either stock springs or lowering springs. Highly recommended !
crazy good price and I don't have to buy top hats! How long is this sale gonna last? Could I get some more info on the adjustable dampening like were the knob is.
| All times are GMT -6. The time now is 03:53 AM. |
