Subaru Legacy Forums
-   Exterior/Aesthetic (http://legacygt.com/forums/forumdisplay.php?f=44)
-   -   Daniel Stern Lighting and Subaru headlight options (http://legacygt.com/forums/showthread.php?t=45991)
f1anatic 10-19-2006 05:12 PM
On Thu, 19 Oct 2006 f1anatic wrote:
> Hello there,
Hi there.
> I have a 2005 Subaru Legacy GT and after 23,000 miles one of my OEM low
> beam headlights just burnt out.
Yep. H7 is an inherently short-lived bulb, and Subaru rather unwisely chose to use the low beams as daytime running lamps, which further shortens the already short life of an H7. There are much better ways of implementing DRLs. If you wish to correct this error on Subaru's part (one of the only errors they made; those are well built and very capable cars),
it is neither difficult nor expensive to do -- just let me know; I carry the parts.
> I would like to replace them with something better. For me, if it > doesn't improve performance, it will not go on the car. I have read a bit about bulbs and I am a bit partial to the OSRAM (not Sylvania) Silverstars.
That is a Plus+50 bulb, equivalent to Philips VisionPlus, Narva
Rangepower+50 and Tungsram Megalicht+50. It'll improve beam performance slightly but at a cost of greatly reduced bulb life. You'd be much happier with Osram's Rallye+65 H7, which works beautifully in the well-designed lampset on your Subaru.
Standard H7: 55w, 1400 lumens, 500 hours
H7 ultra "Plus+50": 55w, 1550 lumens, 225 hours, $17.50/ea
H7 rallye+65: 65w, 2100 lumens, 500 hours, $26.40/ea <--Obvious choice!
The extra 10w is of no consequence as far as electrical power or heat. (those 80w to 100w bulbs are a different story!)
Can also materially improve the high beams with the 9011 bulbs in place of your present 9005s.
The new bulbs are not some tinted or overwattage version of 9005, but rather employ a relatively new technology called HIR, Halogen Infrared. The mechanical dimensions of the bulb are all virtually identical to the 9005, but the bulb glass is spherical instead of tubular, with the sphere centered around the filament. There is a "Durable IR Reflective" coating
on the spherical glass. Infrared = heat, so the coating causes heat to be reflected back to the filament at the center of the sphere. This causes the filament to become much hotter (producing more light) than it can by passing electricity through it, *without* the shorter life or greater heat production that comes with overwattage bulbs (to say nothing of overwattage bulbs' incompatibility with stock wiring.)
Here's the comparison:
stock: 9005, 12.8V, 65W, 1700 lumens, 320 hours
new: HIR1, 12.8V, 65W, 2530 lumens, 320 hours
These bulbs are spendy - $27/ea - but their cost is worth considering in context: Any number of companies will charge you more than this for a tarted-up 9005 with blue colored glass (PIAA and Sylvania Silverstar come to mind) that doesn't produce more light and has a very short lifespan.
The HIR bulbs have a double-wide top ear on the plastic bulb base, this is to comply with the law requiring different bulbs to have different bases. The extra-wide plastic top ear is easily trimmed or filed to make the bulb fit your headlamp's bulb receptacle. Once that's done, they go directly into the headlamp, and the existing sockets snap on.
> I do a considerable amount of night driving and bad weather visibility > is something I emphasize.
Put H3 Gold bulbs ($13.50/ea) in the fog lamps.
> Bulbs are a pain to replace in my GT so i would like something that will burn out in another 20,000 miles.
You're kind of doomed to short low beam life unless you rework those low-beam DRLs, either deactivating them entirely or moving the DRL function to the front turn signals (as is done on most current cadillacs, a couple of Lincolns, many Toyotas and Lexus, etc.). As I say, it's neither difficult nor expensive.
ORDERING INSTRUCTIONS
Please indicate:
The quantity of each item you wish
The type of shipping you wish
(UPS trackable ground shipping is standard; all UPS service levels are available)
The address to which you want the items shipped (if different from billing address)
Whether the UPS driver has permission to leave the parcel at your doorstep if you are not available to accept it in person.
You may voicemail or fax your order toll-free on 1-866-861-8668. Please note this is a recorded orderline only.
Orders may also be sent via e-mail to: dastern AT torque DOT net
We accept Visa and Mastercard. Orders are processed securely.
Whatever method you use, the following information is required in order to process a credit card order:
Card type
Card number
Expiry date
CVV code (last group of 3 or 4 digits on back of card)
Your name as it appears on the card
Billing address
Phone number
Please don't forget to include a note (such as a printout of our e-mail) stating exactly which items you are ordering, and where you wish them sent.
I look forward to hearing from you.
Best Regards,
DS
So I regard Mr. Daniel Stern as a reference and most automotive forums quote him. My question is...if I order:
LOW BEAMS
do I really need to address the HIGH BEAMS ?
FOG LIGHTS
I mean one could literally get a sun tan from that !
Anyone else sporting them ?
Any obvious risks to the headlight assembly from running 10 W higher ? HE claims no danger. Anyone else on the site claiming the contrary ?
f1
Osram H7 65w + Toshiba HIR 9011 Pictures
http://www.legacygt.com/forums/showthread.php?t=124938
(I included the entire e-mail to be used as reference by others)
http://store.candlepower.com/
Mines 10-19-2006 05:45 PM
no need for the high beams
IwannaSportSedan 10-19-2006 06:47 PM
Why not?
Lumens are lumens. more lumens down range is good, especially on high beam, because that throw is further, and more lumens will either throw further yet, or fill the existing pattern with brighter light, or maybe a bit of both. 800 more lumens for the HIR is almost a 50% increase. not inconsequential... and the Legacy's reflectors can put those lumens to use.
I'd probably do that mod eventually, and pair the HIR high beams with ~4300k HID lows. And yellow fogs for the clarity on a short-throw pattern.
Lumens are GOOD, Lumens are GOOOOD.
pillboy 10-19-2006 07:03 PM
:munch:
meier motor sports 10-19-2006 07:11 PM
hmmmm f1 for the win
f1anatic 10-19-2006 07:51 PM
I am waiting on an answer for another question and will probably pull the trigger on the lows and the H3 fogs. I will get around to doing the high beams as well...but realistically I rarely use them. As I said...you could tan if basking in them already and for me mid field power, torque, visibility are more important than top end.
IwannaSportSedan 10-19-2006 08:10 PM
That seems like a rational approach. and probably a really good choice.
But keep in mind, there is more light and less light... not really "mid-range" light. and light doesn't cost quite as much to upgrade as power, and light is useable when power is not...
And luckily, like traction (with good tires), Light (with good bulbs) is one thing Legacy has going for it, in spades.
Four really good light fixtures are SOO nice, compared to all my previous cars having just two fixtures of varying quality.
I love the projectors being able to focus all of their available light on the strict low beam pattern, rather than compromizing half of the reflector or lens focus to high beams... and vice versa for the high beams not having to compromize reflector space for the low beam pattern.
Plus, that just means that high output light sources like HIR, and HID (especially with a HID reflector and cutoff retrofit) can do their best in their own dedicated fixture, and not waste as much of that extra output.
It's like playing really good music through really good speakers. neither gets wasted.
REM87O 10-19-2006 08:41 PM
I like the fog idea. I think I will get a set.
LittleBlueGT 10-19-2006 08:44 PM
More light is always good.
My 95 Civic had 135 watt high beams and 80 watt lows. Wonderful!
My dad was driving behind me when we were driving through the mountains going on a ski trip and he said a lit up the whole side of the mountian!:icon_cool
I never had heat problems, but it was a different car. Or maybe I never had problems because I was always going so fast that they never had a chance to get hot.:icon_wink
Mines 10-19-2006 11:19 PM
how often do you use ur high beams? If you barely use them than you dont need them.
TRS 10-19-2006 11:47 PM
Most of those extra lumens seem to go to lighting up a broader field of view with little added depth. The tree tops are nicely illuminated and reflective surfaces normally above the low beam cut-off are visible further ahead, but when I use my brights they don't seem add much distance. I was driving the wife's ride the other night, which has a pair of Hella driving lights wired to switch on with the highs. Now those throw some extra light waaaay down the road.
TSi+WRX 10-20-2006 06:37 AM
Thanks for the info, f1 ! :D
I think I'm going to go for a set of the Osram Rallye +65s to replace my Silverstar lows.
I'm currently rocking a set of the Narva Golds in the fogs. Combined with just a slight bit of re-aiming (I've got it set to throw just a tiny further down the road, but still angled *quite* downwards), it does really nicely on wet pavement and even as nav-lights, and now also gives excellent mid-field edge-rendition in snowy weather and on plowed-edge roads.
Brothers LBGT and IWSS -
Brother TRS's response is precisely the case. Yes, you've got extra light being put out, but how much of that light is truly useable?
Remember that it's not just the number of lumens - but how the light is focused and shaped that will determine how and what you see under specific conditions.
The average 60W household light bulb puts out something like 4,000 lumen - yes, it'll light up your bedroom nicely, but use it as a porch-light, and see how far you can see out into the back yard....
At the same time, while a hand-held flashlight is a horrible substitute for a proper lantern as room-lighting when the power goes out, it sure can "throw" that light pretty far down a dark hallway or outdoor path, no?
Any measure of light only tells half the story - the other half is told by the optics, reflector housing design, etc.
If you truly want to see farther down the road at night, get a set of properly designed, high-power "driving lights," and set them up correctly to properly supplement your high-beams (and remember to dim them for oncoming traffic!).
I won't say that the HIRs aren't nice. They are - but to me, they are only so for the reasons that TRS cited above, that they seem to light up a broader field and highlight reflective surfaces farther away, both of which adds a bit to my night-time driving "comfort." However, they are still limited by the size and design of your current reflectors.
But to think that they're going to be a substitute for a good set of properly designed and set-up driving lamps in terms of pure throw and penetration - that's definitely not going to happen. :)
unclemat 10-20-2006 06:58 AM
Speaking of "more light" - any suggestions for beefing up output of reverse lamps (in wagon)? These are pretty dark. I am gonna replace one of them with a fog lamp, so it will be twice as bad (just one lamp).
meier motor sports 10-20-2006 07:26 PM
yeah i would like some air craft landing lights for reverse on my shwagone
bugblatterbeast 10-21-2006 09:29 AM
It is actually closer to 1000 if you are referring to the single walled (cheap) non-halogen bulbs. Most household bulbs put out 16-20 lumens per watt when new. Much less when they are aged.
