Exhaust informational thread
This is something that comes up all the time. I get PMs from people asking for information in regards to part numbers and other aspects of exhaust part installation. So, here is a thread with all sorts of information in regards to exhaust parts.
This is for all the DIY people out there... you will do a much higher quality job if you follow the specs below. Downpipe-to-catback torque spec...........13.0 ft-lbs Axle-back torque spec ..........................35.4 ft-lbs Exhaust bracket torque spec ..................26.0 ft-lbs Transmission bracket torque spec ............26.0 ft-lbs Downpipe-to-midpipe torque spec ............26.0 ft-lbs Downpipe-to-turbo torque spec .............. 26.0 ft-lbs Uppipe-to-turbo torque spec ...................26.0 ft-lbs Turbo bracket @ up-pipe torque spec .......26.0 ft-lbs Turbo bracket-to-block torque spec .........24.6 ft-lbs (highly unlikely you will need this one.) Head-to-manifold torque spec .................29.8 ft-lbs Manifold-to-crossover pipe torque spec .....26.0 ft-lbs Manifold-to-uppipe torque spec ...............26.0 ft-lbs Manifold heatshield torque spec ...............9.6 ft-lbs Front 02 sensor torque spec ...................22.1 ft-lbs Rear 02 sensor torque spec ....................15.2 ft-lbs Intercooler-to-turbo flange torque spec ....11.6 ft-lbs Intercooler brackets torque spec .............11.6 ft-lbs By-pass valve-to-intercooler torque spec .. 4.8 ft-lbs In addition, here are the part numbers for all the exhaust gaskets too. Head to Exhaust Manifold Gaskets - 2 are required to replace in case you install a header. 14038AA000 Driver's Exhaust Manifold to Crossover Pipe gasket 44022AA160 Crossover Pipe to Pass Exhaust Manifold Gasket 44011FA020 Exhaust Manifold to Uppipe Gasket 44022AA170 Uppipe to turbo Gasket 44022AA150 Turbo to Downpipe Gasket 44022AA180 Downpipe to Midpipe 44011FE000 Flex Joint Gasket (the donut) 44022AA122 If you guys want, I might also include a how-to on UP/DP installation, but frankly, those are a dime a dozen on WRX sites.. More information Installing Exhaust Gas Temperature Sensor Tools Needed:
Hey Jose,
Could you add TMIC, and turbo (to bracket to block, etc) torque specs as well? Thanks! |
Awesome, exactly the thread I was looking for. Thanks a bunch!
Done, added all those specs too... even the tiny BOV one :lol: |
Nice Jose. So you're trying to say I don't just torque everything till the bolts snap off... huh... who knew?!?!? :lol:
Edited for typos that made my post just about incomprehensible ;) |
added 02 sensor torque specs
wow, good timing... I was just going to search for this. Installing headers this weekend.
Added a section in regards to installing a EGT sensor. Took it out of my Defi How-to that I did for the STi guys a while back
Nice job Jose,,I just had my right arm recalibrated too:icon_wink
Very nice! Thanks Jose!
Nice! :D
Perfect for my UP/DP & Prodrive install in a couple of weeks! Thanks! :D
About to do headers install, just called the dealer who has gaskets in stock. Here is the price I was quoted over the phone (don't know if this varies):
Header - Block = 13.22 each (x2) Uppipe - turbo = 11.83 (x1) Funny thing was... I forgot about this thread and had him searching on the computer for a few minutes. Then I said... oh wait... crap I have the part numbers! Point of story... get part numbers before you call the dealer... because it might take them 10 minutes to find it in the system. I am going to sell my Crucial gaskets. They are good gaskets, but I am just too lazy to heat cycle them a few times! |
What were the part numbers for the uppipe studs and the exhaust manifold studs?
| All times are GMT -6. The time now is 05:18 PM. |
