Subaru Legacy Forums
-   Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) (http://legacygt.com/forums/forumdisplay.php?f=12)
-   -   Will these parts fit? (http://legacygt.com/forums/showthread.php?t=2814)
bisk 09-10-2004 07:49 AM
I'm trading my 03 WRX in and getting an 05 Legacy 2.5GT Ltd Wagon and I was wondering if the STi Short Shifter that's in my WRX will fit in the new Legacy. What about my summer rims (Rota Tarmac II - 17x7.5 and 48mm offset - I think) with 215/45 rubber?
ShaggyGT 09-10-2004 08:19 AM
The rims/tires will work but I doubt the short shifter will.
-Matt
Th3Franz 09-10-2004 09:17 AM
It's been confirmed that the WRX short shifter will not work.
Drift Monkey 09-10-2004 09:46 AM
The stock WRX shifter, however, appearently DOES work...:P
*Jedimaster* 09-10-2004 10:18 AM
I thought the ball was a different size?
And what would be the benefit to doing it? If there is one, I still have my stock WRX shifter...
Drift Monkey 09-10-2004 10:28 AM
You just swtich balls! :P The benefit is shorter throws! Maybe add some kartboy bushings...and cheap short shifter!
ShaggyGT 09-10-2004 10:35 AM
Yes it does. All it takes is that you swap the ball's on the shifters and it will bolt right in. I just get tired of reposting it over and over again since it seems no one either reads it or remembers....
-Matt
*Jedimaster* 09-10-2004 12:13 PM
So how do you remove the ball?
This is my stock WRX shifter: http://premium.uploadit.org/cultofth...for-sale13.JPG
Drift Monkey 09-10-2004 12:35 PM
-Matt
I DID remember! :P
ShaggyGT 09-10-2004 02:01 PM
Jedimaster: Take a look at the bottom of the shifter where the white ball is. You will see a black pin that goes through the ball. Take a small pointed chisel or tap and tap the pin out with a hammer. It will come right out. Do the same on the stock legacy shifter and put the ball from the Legacy shifter and install it on the WRX shifter and tap the slide pin back in. After your done grease it up and reinstall it and your done. The Legacy shifter is secured with a 'C' clip which is what holds the shifter in the linkage. The 'C' clip is probably the most difficult part, and even that is easy.
Drift Monkey: Yeah I know you remembered. You are good about absorbing information. If it werent for you and the few others, then I would feel I was waisting my time even posting my findings.
-Matt
*Jedimaster* 09-10-2004 02:08 PM
Cool- thanks! Your posts are not to be ignored :)
Drift Monkey 09-10-2004 02:14 PM
-Matt
You are appreciated man!
