Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Help! 05 legacy gt ltd issues (http://legacygt.com/forums/showthread.php?t=215109)
B_riz0212 10-06-2013 07:49 AM
Just purchases my first subaru. Love the car, however having an issue with it... Starts fine the first time of the day, and if it sits and cools before I start it again, still fine. But if the engine is warm and I start it after it only sits for 5-10min it shutters, the rpms are <500 and not throws a misfire code. Any suggestions? Already changed plugs and boots.
Sent from my iPhone using Tapatalk - now Free
B_riz0212 10-07-2013 08:44 AM
Anyone??
Pazuzu 10-07-2013 10:41 AM
You might check your fuel pressure. Does the car have any mods? A little more info might help.
B_riz0212 10-07-2013 10:44 AM
Only mod is an AEM CAI
B_riz0212 10-07-2013 10:45 AM
Car has 137k miles
Berzerklo 10-08-2013 11:51 AM
How long has the intake been on? Well before this issue started?
Sounds like a vacuum leak.
silen7guardian 10-08-2013 12:20 PM
Cold Air Intake?
More like heat-soaked air intake, the way they're typically installed. If that's the only mod, and you still have the factory snorkel, it may be helpful to revert that.
Max Capacity 10-08-2013 12:57 PM
Yep, put the stock intake back on. It's good until like 400whp.
B_riz0212 10-08-2013 07:30 PM
The intake was on it when I bought the car. I don't have the OEM one but I will find one either on eBay or maybe at a local salvage yard. Thank you all. Will let you know how it goes.
B_riz0212 10-08-2013 10:57 PM
Would a k&n typhoon or spt intake be better, or doesn't cobb make one too? Just a thought, they are easier to find than the OEM one.
stanjk3 10-09-2013 05:42 AM
Yes there are plenty of aftermarket intakes, but they will all have the same problem - you'll run lean without a tune.
You may be able to find a stock intake at a salvage yard.
B_riz0212 10-09-2013 09:57 AM
Found one for 100$ locally. Woot woot!
