Subaru Legacy Forums
-   Second Generation Legacy (1994 - 1998) (http://legacygt.com/forums/forumdisplay.php?f=95)
-   -   EGR Valve Compatibility (http://legacygt.com/forums/showthread.php?t=214294)
jamesm113 09-17-2013 08:15 PM
2 Attachment(s)
Does anyone know if an EGR valve from a 96 Legacy 2.2L would work with my 97 Legacy 2.2L? They have different Subaru part numbers (14710AA530 & 14710AA611)
The vacuum port is on a different side of the valve and the current vacuum hose won't reach. I'm worried a longer hose will kink & interfere/get burnt/etc or that the specs are different in the older part number.
Zues Marine 09-17-2013 08:21 PM
i swapped between a 95EJ22 and a 98EJ25 and had no problems
kurtis9813 09-18-2013 08:29 AM
I put an egr valve from a 98ej25 on my 95ej22. They looked the same, and had the hose connector on the same side. Everything worked fine. I would assume in your case it would be fine, just get a longer hose that will reach. I can't think of any reason why anything would go wrong. If it's not compatible you might just end up with a P0400 egr flow malfunction code or another one of those egr codes.
jamesm113 09-18-2013 10:48 AM
The thing is, I'd have to buy one to find out if it would work or throw a P0400 error. And probably not be able to return it, since i knew it might not fit to begin with. And EGR valves are bit pricey for our cars.
I think both the examples you guys posted use the same EGR valve (pre97 EJ22 and post98 EJ25)
johnegg 09-18-2013 10:58 AM
what Pxxxx code are you trying to fix?
buy a used one and see if that helps?
if buying new, buy the right one?
using a longer hose will not be a problem if you route it correctly and use zip ties to hold i in place.
buy a foot more than you need.
if you think you need 12", buy 24" just to be safe.
jamesm113 09-18-2013 11:06 AM
My EGR valve has a vacuum leak that I think is responsible for a P0170 - long term fuel trim out of range & more recently, a P0130 - O2 sensor malfunction.
johnegg 09-18-2013 07:31 PM
http://www.obd-codes.com/p0170
jamesm113 09-18-2013 07:55 PM
Right. Both P0170 and P0130 have vacuum leaks as a potential cause. And if I spray parts cleaner on my EGR valve - more specifically, on the metal rod - my engine revs.
johnegg 09-18-2013 08:00 PM
what, which, where metal rod?
jamesm113 09-18-2013 08:12 PM
1 Attachment(s)
If I spray where the arrows are, it revs. Tried cleaning it with no luck.
johnegg 09-19-2013 05:09 PM
ok, you have found the leak.
i still do not understand why you are considering an EGR valve that does not fit your engine?
if you are buying a new one just get the right one.
personally i would try used for a few bucks.
somebody is bound to have one somewhere sitting around.
especially if it is not an exact match.
my guess is that the same year EGR valve from a different model subaru will be an exact match.
suabru does not like to use different parts on different cars, in the same years.
it can happen, but usually only in ''transition'' years, like 1999.
jamesm113 09-19-2013 06:04 PM
Ah. Sorry for the confusion. I bought a used replacement valve off eBay that was supposed to fit my vehicle. It was in very nice condition and was $50. Turns out it was from a 96.
I wanted to know if it was worth using or if I need the correct style. I couldn't find any used ones for my style, and the new ones are over $160.
johnegg 09-19-2013 06:27 PM
try it.
worst case it does not help and you wasted some time and a few dollars on a gasket and some hose.
but if it is in good condition, i bet it works.
jamesm113 09-30-2013 01:23 PM
Well, I was able to return the one that didn't fit and find a used part that does fit.
However, the correct fitting one still has a vacuum leak (a little bit smaller than the original). The idle is a bit better now, but still having issues. Idle will surge & pulsate. Sometimes it will even stall.
So I think the best course of action would be to get a new one, but I just want to confirm this is likely the source of problem before dropping $140+ on it. Thoughts?
Thanks!
jamesm113 10-05-2013 03:24 AM
Well, I bought the new valve & installed it tonight. It was standard motor products one. Idle is still poor, and the new valve has a vac leak in the exact some spot I pictured above. :mad::mad::mad:
