Subaru Legacy Forums
-   Exterior/Aesthetic (http://legacygt.com/forums/forumdisplay.php?f=44)
-   -   2010+ CS lip on 2010 LGT (http://legacygt.com/forums/showthread.php?t=213532)
valkrie hunter 09-03-2013 02:28 PM
Just wanted to start a documentation on a project that should have been a very bad idea..
So with the limited lip options for 5th Gen Legacies, I wanted to try something different. Bought a WRX CS style 1 replica lip and started seeing how much work it would take to get it to fit.
Let me know what you think!
http://i11.photobucket.com/albums/a1...IMAG1332-1.jpg
Lip getting mocked up and glued
http://i11.photobucket.com/albums/a1...IMAG1336-1.jpg
valkrie hunter 09-06-2013 02:50 PM
So after fabbing up the lip, I felt I needed to strengthen the brackets between some of the pieces (where the silver is seen on the pictures above). I used acrylic sheets to hold everything in place. Then filled each of the pieces with plastic epoxy from JB Weld and sand everything smooth. I need to finish fabbing up the brackets from when I initially cut the lip to fit the contour of the bumper
http://i11.photobucket.com/albums/a1...l/IMAG1343.jpg
http://i11.photobucket.com/albums/a1...l/IMAG1346.jpg
http://i11.photobucket.com/albums/a1...l/IMAG1347.jpg
valkrie hunter 09-10-2013 10:10 AM
Finally finished up just in time for Subiefest!
http://i11.photobucket.com/albums/a1...l/IMAG1349.jpg
http://i11.photobucket.com/albums/a1...l/IMAG1354.jpg
http://i11.photobucket.com/albums/a1...l/IMAG1351.jpg
What do you guys think?
BigBopper 11-24-2013 01:07 PM
Finished product looks good!
Looks like it was a shit ton of work. I give you credit for seeing the project through. ;)
valkrie hunter 11-25-2013 12:37 AM
Ahah thanks! I definitely had my doubts though. Especially when I started cutting everything in pieces. May want to go a different route if I ever have to redo this lip
