What does this cel mean?
So I got in my car tonight and I had a cel and my cruise light was flashing, what does this mean do I need to do something immediately?
just means theres a code in it get it scanned
Jay |
Most parts stores will scan them for free.
for some reason when I was dangerously low on antifreeze my car did this. probably not your problem but doesn't hurt to check.
-Open the fuse panel by your left knee
-Pop off the panel to the left of that by the door -Find a set of green and white clips tucked up there -Clip corresponding colors together -Insert your key in the ignition -Have a pen and paper ready -Turn to 'ON', don't crank -While the gauges are sweeping press the trip button -Unclip before driving again Your car has a built in code reader, and will read off all CEL codes stored in the ECU where it displays the mileage. Look-up code here: http://legacygt.com/forums/showthrea...els-26113.html |
Thanks for the input guys my cruise light flashes and cruise doesn't work it's at the shop now
Got it into the shop and they ran a health check, and the diagnosis is that it has a misfire in 2 & 3 causing backfires, the recommend replacing the plugs and coilpacks
vBulletin Optimisation provided by
vB Optimise v2.6.3 (Lite) -
vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
