Subaru Legacy Forums
Subaru Legacy Forums (
-   Second Generation Legacy (1994 - 1998) (
-   -   Shift light (
Sludgeroo 07-17-2013 01:17 PM
Shift light
Please don't ask why, but if I were to wire in a shift light, which wire would i need to tap into on the coil plug/ or the cluster to send it to the light?
mailman 07-17-2013 11:09 PM
Sludgeroo 07-18-2013 05:17 AM
Damn iit!
pleaidestar 07-18-2013 08:32 AM
Lol..I knew someone was gonna do it.
I'm not so sure about where to draw power for it in the subarus, but I turned the check engine light in my civic into a shift light after I had the p28 ecu kromed, it was part of the tune I got. No wires or anything, could be the same with an aftermarket light. Maybe just run a power wire and relay into the vss since your intake is map based. But idk Alex....maybe?
Sludgeroo 07-18-2013 10:06 AM
I figured that
Zues Marine 07-19-2013 12:19 AM
the only shift light i'd ever put in my car would be an l.e.d integrated into the cluster
spooln30 07-19-2013 06:07 AM
Dude just shift when you hit 6500 rpm. LOL Over the years of road racing I've learned to listen to the sound of my engine in the Supra and shift. I do have led shift lights molded into the gauge bezel that can be annoying at times from how fn bright they are.
pleaidestar 07-19-2013 07:13 AM
I think he is actually looking for an answer, unfortunately I don't have one for you because I'm more or less electrically retarded...duh-ta-duuuuh.
Stang70Fastback 07-19-2013 12:31 PM
So, you still haven't told us why.
Sludgeroo 07-19-2013 07:10 PM
Because racewagon
Stang70Fastback 07-19-2013 10:01 PM
Fair enough.
monkeyposeur 07-19-2013 10:18 PM
Because girlfriend wants to drive racecar?
Sludgeroo 07-20-2013 04:49 AM
That too.
spooln30 07-21-2013 12:18 AM
Did you find the wire? Just use a test light and which ever wire from the coil pluses tap into that one.
Sludgeroo 07-30-2013 11:13 AM
Thanks, girl drove the wagon and now wants one.
