Subaru Legacy Forums
-   Naturally Aspirated Powertrains (2.5i, 3.0R, 3.6R) (http://legacygt.com/forums/forumdisplay.php?f=11)
-   -   6 cyl oil filter socket ? (http://legacygt.com/forums/showthread.php?t=210181)
Krusty783 06-30-2013 10:22 AM
Does anyone k ow where to get a 78mm oil filter socket for a 3.6R oil filter? None of the auto parts houses have that size and I can't find one on the Internet that's not on some sketchy Chinese website...
Sent from my iPhone using Tapatalk.
Dodik 06-30-2013 11:03 AM
Why cant you just use adjustable filter wrench?
theflystyle 06-30-2013 11:09 AM
It should only be hand tightened.
BadTrainDriver 06-30-2013 11:22 AM
This.
BadTrainDriver 06-30-2013 11:23 AM
I imagine he's looking for one to remove the filter, and if it's like the one I took off my car from the factory, you'd have to have hands like the Incredible Hulk to remove it without some kind of wrench!
Krusty783 06-30-2013 12:58 PM
Filters say to tighten 3/4 of turn after o-ring makes contact. If you can do that by hand, go try out for world's strongest man.
Obviously you don't have a 3.6R. If you did, you would know that if you left the filter hand-tight you would leave a trail of oil on the road.
There is a piece of the block that sticks out and catches on a 3-prong universal wrench & I'm getting tired to spending 10 minutes trying to get an oil filter on.
BadTrainDriver 06-30-2013 03:15 PM
I had no problems installing the oil filter the two times I've changed the oil.
Tightened by hand just fine.
theflystyle 06-30-2013 04:24 PM
I don't have a 3.6 but I have had plenty of cars, including many Subaru's where I have not had to use any tools to remove/add an oil filter.
apexi 06-30-2013 09:58 PM
Here's one option, it gets a little pricey with shipping though.
http://www.subarupartsforyou.com/cp_...p?partid=19411
From what I'm reading, something like the lisle 61550 might work too even though it's 80mm and not 78mm.
BAC5.2 06-30-2013 10:09 PM
You should hit the gym.
I've owned my fair share of Subaru's, putting probably close to 500k on all of them combined. Never once have I used any kind of tool to install an oil filter, and never once have I left a trail of oil caused by a leaking filter. That's around 170 oil changes without a single hiccup, and that doesn't include the hundreds of oil changes I've done on other cars.
As for removing a stuck filter, a screwdriver never fails.
gimpydingo 07-01-2013 09:05 AM
I picked up a socket at O'Reilly. Its a dual size, fits my LGT and 3.6. I use it to remove only, and always hand tighten. I've never had a leak. I used a socket to put on a filter once a loooooong time ago. Big mistake. Unless you are some beast of a (wo)man, you can crank that thing hard by hand and really have no issues.
