Subaru Legacy Forums
-   Intake and Exhaust (http://legacygt.com/forums/forumdisplay.php?f=73)
-   -   SPT Intake (http://legacygt.com/forums/showthread.php?t=209442)
Niko_lgt 06-16-2013 01:00 PM
SPT Intake
Hey guys, someone told me that the SPT intake is as less efficient as the stock one?
Thoughts on this?
It would be a shame to have to put the stock one back in or have to get another one since I paid around 160 for the SPT.
idiot4hire 06-16-2013 10:31 PM
Stock air box is fine until you get well into the 300whp range. Definitely don't use it on a stock tune. Money would be better spent on a rear sway bar
fahr_side 06-17-2013 01:51 AM
It's a really crappy intake and notoriously difficult to scale properly. I always beg people to take these things off and have me tune them with the stock intake on instead. As mentioned, your stock intake is good well past 350whp and no gain will be found below that range.
Pros: Sounds kewl mang.
Cons: Can hardly be tuned around to get a stable AFR, and running lean will damage your engine. May get less power than stock depending on how much work you put into keeping hot air off the filter. Flows no more than stock until into much higher flow ranges than your stock turbo can manage.
chimera 06-17-2013 02:52 AM
Take it back for a credit, get a high flow panel filter for the stock box and put the change towards a tune
fahr_side 06-17-2013 03:18 AM
AVO / K&N etc. panel filters are not shown to make any more power, but have notably poorer filtration efficiency.
Niko_lgt 06-17-2013 10:10 AM
Well so far my mods with this intake that I've had on for over 6 months.
1. Perrin inlet hosing.
2. BNR 16g turbo.
3. Invidia uppipe.
4. Invidia downpipe w/ high flo cat
5. 3" catback exhaust.
6. Infamous performance oil filtered kit for the turbo.
7. Forget exactly what they are called. The butterflies in the TGV I believe. Had them removed.
8. New spark plugs, but overall that's it. I will be getting a tune. Will this be enough of airflow for the SPT? Or just overall this intake isnt any good?
I unfortunately don't have a heat shield for it. But could get one, depending on how necessary it is? Or I'll just install the stock one back in.
Niko_lgt 06-17-2013 11:50 AM
Just the intake has been installed about 6 months, ^^^^
Everything else I'm having done now.
idiot4hire 06-18-2013 03:40 PM
If your having a tuner do all that ask them what they think you should do
Niko_lgt 06-18-2013 05:53 PM
Yea I'll see what he says, thanks for the advice and opinions though guys^^^
