Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - 2014 ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   Yes another oil question (http://legacygt.com/forums/showthread.php?t=208518)
4thsubaru 05-30-2013 08:20 AM
My 2010 legacy Gt has required me to add oil before the next oil change on two occasions now. I do mostly city stop & go.
I know Subaru engines has always had a history of consuming some oil going back to the 2004 Sti. I had one and never had oil consumtion issues.
After reading a bucnch of threads their is talk of comprssion testing etc etc.
The question is how much oil loss is normal and what is not normal and/or worrisome. Example if you add 100 ml vs adding 500ml.
Thanks for your inputs
acumenhokie 05-30-2013 08:26 AM
How long are you going between oil changes and what brand/weight are you running?
Looks like historically it's 1qt per 5k miles. Not sure if it would be any different for the 5th gen since it's still an EJ25.
http://legacygt.com/forums/showthrea...oni-14926.html
Rutchard 05-30-2013 09:06 AM
How much oil did you have to add? How often do you check your oil?
4thsubaru 05-30-2013 09:09 AM
600km (3700 mile) per manual recommendation 5W-30 because of the cold weather
I have put in less than a quart each time
4thsubaru 05-30-2013 09:10 AM
on both occasion about half a quart and I was close to oil change time.
Unfortubately not often enough, the oil light for level warns me first.
dawkins20 05-31-2013 12:09 PM
My 4th gen didnt use much oil at all, the 2011 LGT has consistently used 1qt/slightly less than 3000 miles. Slightly annoying since the pistons/block are the same so I'm not sure why the consumption is higher.
eckseleven 05-31-2013 12:44 PM
Some cars use more oil than others. Same goes for 4th gens. I had to top off my factory fill once. During the time I ran Mobil 1 I had to add about 1/5 qt between oil changes. Since the switch to T6 and then to Edge Syntec, I don't have top it off all. Oil level stays at the full mark the whole time (3750m OCIs).
4thsubaru 05-31-2013 01:11 PM
I think I will make that switch to syntetic
hmmrdwn 05-31-2013 09:41 PM
I ran T6 and the mileage went down. I think T6 would be great with a turbo though.
nm+ 05-31-2013 10:26 PM
This is absolutely nothing to worry about. 1qt per 3700mi is very normal.
SurlyOldManMN 06-01-2013 01:32 AM
Amazingly, this appears to be true. Especially lately for us 5th gen folks.
