Subaru Legacy Forums
-   Mountain West (http://legacygt.com/forums/forumdisplay.php?f=47)
-   -   Synapse Synchronic Diverter Valve/BOV (http://legacygt.com/forums/showthread.php?t=207013)
hectik303 05-05-2013 04:34 PM
Needing to sell this DV/BOV it doesn’t run right with my setup I need to go back to a HKS SQV IV, its less than a month old and comes with the HKS flange and all the extra parts. Make me an offer no low ball. Paid $240-$270ish for it I think. Email me @ Hectik3oh3@gmail.com
This Synchronic DV kit comes with an adapter flange for the SSQV Series BOV and A 1.25'' hose end adapter for discharge air recirculation.
From tyhe Synapse website:
Synchronic DV is the first, truly compact, zero-diaphragm, high-flow Diverter Valve with a blistering actuation time measured at 25 milliseconds. Mass air flow (MAF) and speed density (MAP) applications can apply the new design in push or pull orientation with the ability to fully re-circulate or vent-to-atmosphere the valve's discharge. Construction is based on near-net investment casting of aerospace-grade Aluminum for the body, followed by post-process CNC machining of all components including the forged billet 6061 actuator assembly. A complete selection of available mounting flanges are interchangeable between the SB and DV series and users can either upgrade from an existing BOV/DV by simply bolting on an adapter or weld on to a new project using the Aluminum or Stainless weld flanges. Boost/vacuum connections are made via 1/8th NPT threaded bosses that accept either Boost Connect or included nickel-plated-brass barb fittings. Each assembly is pressure tested to withstand 60 psi and positive lock clamshell retainers are included with each assembly for fitment.
