Subaru Legacy Forums
-   Transmissions (http://legacygt.com/forums/forumdisplay.php?f=79)
-   -   Rock engine forward to replace clutch (http://legacygt.com/forums/showthread.php?t=205221)
CapnJack 04-07-2013 02:33 PM
I'm in the midst of a stage 3 build and am installing TGV deletes, turbo, UP, FMIC, etc. Basically, the engine is stripped right now. I also plan to install a new clutch. Instead of pulling the transmission, I figured I might as well leave it in place and rock the engine forward instead. I remember seeing threads on this and for the life of me can't find them.
Does anyone know if I can simply rock the engine forward on the mounts enough to get at everything or do I need to use an engine hoist?
suds2250 04-09-2013 08:28 PM
You need a hoist. Remove the radiator to gain clearance and bring the engine forward.
CapnJack 04-10-2013 06:14 PM
I kind of figured after looking at it a little more. I found a local place to rent a hoist for $25 a day.
Thank you!
