Subaru Legacy Forums
-   Walkthroughs :: Performance Modifications (http://legacygt.com/forums/forumdisplay.php?f=37)
-   -   WRX pedal upgrade (http://legacygt.com/forums/showthread.php?t=205035)
DeltaNu1142 04-04-2013 04:08 PM
WRX pedal upgrade
Is it a performance mod? Hardly, but I'm not sure where else to put this.
Those of us driving lowly non-Spec.B Legacy GTs are stuck with the plain black pedals. I ordered the OEM WRX pedal pads only to find that the accelerator pedal is one solid piece of plastic, from the arm down. There is no rubber pad or separately-pivoting pedal (at least on the '08-'09).
So aside from the WRX clutch & brake pedal pads, I purchased a dead pedal from the dealer for $20. I then found that the 2012 WRX accelerator assembly is identical to the 2009 Legacy assembly. Two 12mm nuts removes the assembly, and the WRX assembly is plug & play.
Front of pedals:
http://i.imgur.com/KNKzFVXl.jpg
Rear of pedals:
http://i.imgur.com/QZ99zhgl.jpg
Finished product:
http://i.imgur.com/U8JmUhal.jpg
angeltalin 04-04-2013 06:30 PM
I was close to trying this out myself! glad it worked out !
JeepGuy25 04-11-2013 12:29 PM
Are there part numbers/options to do this upgrade to an 05 5EAT car? Not even sure if there is an auto brake pedal cover with this design...
I saw that you can get the pink STI pedal covers, but I would Love to get the alum pedals with black dots. They'd look great after I switch to black carpet.
J.
DeltaNu1142 04-12-2013 04:41 AM
Just do the research. The 2012 WRX pedal will likely bolt up. There is probably a comparable auto brake cover out there somewhere.
fahr_side 04-12-2013 07:05 AM
Do you have a part number for the '12 WRX gas pedal?
DeltaNu1142 04-12-2013 07:25 AM
I do not... I examined some photos from a guy on NASIOC & pulled the trigger. It's an exact match except for the pedal treatment. It is NOT the same part number as the LGT with a different pad, though; the total pad thickness is the same between the two.
Here's a 2011 set from eBay that would have saved me about $60: LINK
fahr_side 04-12-2013 07:28 AM
Was just wondering if it's the same part as the GRB STi...
DeltaNu1142 04-12-2013 07:32 AM
The best I can say is that I saw drive-by-wire accelerator pedal assemblies that clearly would not work. Pedal 'arm' angles (lateral) were off. Bolt patterns differed. The '11-'12 (and maybe other year) WRX match up exactly.
EDIT: Here's another one that looks like it will match. It's advertised as a 2007 WRX STi assembly, and has a close-up of the Denso p/n:
LINK
P/N: 36010FE040, verified here.
Brett 04-12-2013 10:18 AM
nice! i want a set for mine. standard rubber pedals suck
DeltaNu1142 04-12-2013 10:25 AM
Not rubber. Your accelerator pedal is hard molded plastic.
scosocROKKER88 04-13-2013 01:49 AM
lookin good!
beats the crap out of those canadian tire brand bullsh*t hahaha
going to get it done this weekend you've inspired me!
0Subie9 07-06-2013 07:30 AM
So the 2012 clutch brake and gas pedal bolt right up to the 2009 legacy? I'm very interested in doing this any help would be appreciated.
Sent from my SCH-I535 using Tapatalk 2
DeltaNu1142 07-07-2013 05:26 AM
That is correct. Bolt pattern, size, electrical connections, position, are all the same between my 2009 LGT and the 2012 WRX part I bought. I've been running it this way since I started this thread.
0Subie9 07-07-2013 03:45 PM
I'm new to these subies and have only had my legacy for a week now. What and where are the electrical connections.
DeltaNu1142 07-07-2013 03:52 PM
If you have a Legacy, you can open the driver side door, crouch down in the footwell, and have a look. It's drive-by-wire. One multi-conductor electrical plug. Same on the LGT as it is the WRX. It will take more time to open the door and crouch than it will to unplug the connector.
