97 LGT with jdm 2.5 p0400 egr code
Hi all, ok so I picked this car up about 8 months ago for a steal. As the PO was not able to make it run proper,
It has a jdm ej25 na but also no egr, I know of tapping and drilling the head and use the north American intake but that's not an option as I don't have it, its in the car and untilled I do a clutch its staying there lol. The issue is I'm setting a p0400 egr code, and as its non flashable Ecu and iI can't eliminate the code that way, I was curious if there was a band aid repair for it, the code deals with rasabal nit hard part fault. I fixed that one with installing a solinoid. As long as its plugged in no code. But the 400 deals with insaficiant flow. That's moniterd by watching for o2 movement timed with the valve opening. How do I or even can I get around this? And any idea if it pulls timing if its set? Thanks for any insight! |
vBulletin Optimisation provided by
vB Optimise v2.6.3 (Lite) -
vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
