Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - 2014 ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   Tein S Techs, 18x8, +35, will I rub?? (http://legacygt.com/forums/showthread.php?t=204344)
Predator_ds 03-25-2013 10:07 AM
Hey guys, new owner here of a 2010 Subaru Legacy GT.
Was just curious if anyone here is running this setup and if you had any issues.
Tein S Tech springs
18x8 wheels
+35 offset
If I will have issues, can anyone recommend the most aggressive offset i can run with this setup without having any problems?
minuccims 03-25-2013 08:41 PM
You will not rub. How low are the Teins?
I have RCE blacks with 245/40 tires on 18x9 rims +35 offset.
No rubbing.
Predator_ds 03-25-2013 09:55 PM
No rubbing.
Thanks a lot bro. The advertised drop on the Teins is 1.6" front and 1.3" rear.
Do you have any pics of your setup that you could post? would love to see it.
Rutchard 03-25-2013 10:47 PM
Originally Posted by Predator_ds (Post 4358310)
18x8 wheels
+35 offset
Remember folks, offset is dependent on wheel width.
http://img.photobucket.com/albums/v3...sdifficult.jpg
the 9" wheel is going to poke out and in an extra half inch
Scooby-GT 03-25-2013 11:06 PM
Well, if minuccims's 9 inches aren't rubbing, Predator_ds' 8 inches will certainly not. :lol::lol:
What tire size are you running Predator_ds? That will be a factor as well.
Predator_ds 03-26-2013 08:05 AM
I was planning on running 245 40 18.
My goal is to achieve as aggressive a stance as possible with minimal compromise to the comfort and practicality of the car.
Scooby-GT 03-26-2013 11:13 AM
Go for some 245/45/18, they are taller than spec, but will fill up the tirewell more, and overall fit the look better. There is someone here with 245/40/19, which has the same diameter as 245/45/18. Do a search, you'll find some pics there.
Rutchard 03-26-2013 12:37 PM
Don't forget to get rid of your spare if you go with a taller than stock tire to fill your wheel wells. If a new vs used tire is too out of spec for the AWD system, I can't imagine how bad a tire that is an inch shorter than the other 3 would be.
